Can't update my server TLS Certificate
webtopia
Hi All,
I was running Centos 7 on my server and was running into all sorts of issues. So decided to do a complete clean install of AlmaLinux 8. From there I ran the install of directadmin.
My plan was to recreate all my accounts and upload my websites (I only have a few).
Everything went OK but directadmin setup under https://server-xxx-xxx-xxx-xxx.da.direct:2222/. (where the Xs represent my IP address).
I want to access through https://xxx.xxx.xxx.xxx:2222
So I went about updating everything in the admin account to refer the IP address directly. The issue is the TLS certificate was setup for the https://server-xxx-xxx-xxx-xxx.da.direct:2222/ and it shows my server as insecure. So I tried to manually update it in SSH and I now have the message
x509: certificate signed by unknown authority
Is there an easy way to refresh the TLS certificate for the server using the https://xxx.xxx.xxx.xxx:2222 format or the actual server name (I have a domain registered for my server).
Not for the websites themselves they have been setup ok.
Any help much appreciated.
This is a hostname to help you start.
You have to create your own FQDN hostname, best is before installation, but afterwards it can be changed, just more work.
You can fix it by following this manually very carefully, check all things mentioned!!
P.s. you won't get an SSL certificate on an ip. You need a hostname.
Thanks for your helpful response.
I was most of the way there. I forgot to create an A record for my domain (I have now and called it svr). Then a reboot and running the letsencrypt script gave me the right certificate.
Then another reboot and accessing directadmin through the server name https://svr.mydomain.extension:2222 results in a secure directadmin site.
