I set-up multi server last week between 2 directadmin instances.
This worked fine that same day.
Now when I try to test the directadmin multi servers, I get following errors in both directions on the server:
server.domain.com : : Timeout while trying to connect to 94.120.0.73
Unable to connect to secure socket
Some I/O error occurred. The OpenSSL error queue may contain more information on the error. If the error queue is empty (i.e. ERR_get_error() returns 0), ret can be used to find out more about the error: If ret == 0, an EOF was observed that violates the protocol. If ret == -1, the underlying BIO reported an I/O error (for socket I/O on Unix systems, consult errno for details).
openssl error queue:
empty error queue. ret=-1
errno: Bad file descriptor
I didn't change any firewall config between last week.
I tried deleting the link and setting it up again, but I keep on getting the same error.
I can connect to both servers properly using the domain name, using ssl on port 2222.
