DirectAdmin 1.683
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.683.
DirectAdmin 1.683
In changelog under Software update i see -
  • csf updated from 14.24 to 15.00
    from what source CSF core files will be retrieved now.
The latest CSF 15.00 release is published in the official Way to the Web repository. We store a copy of the latest package on our mirror servers be able to add version number to the filename. And to open a path for releasing new versions in the future.
How would DA 1.682+ or the routines for v15.00 GPLv3 switch impact things if I decide to switch to my own hosted CSF mirror version that restores the download/version check routines in CSF - so that CSF -u and auto updates will look to my CSF mirror for updates? My mirrored CSF version with restored version check/download is currently on v15.01 version label. Just curious if DA 1.682+ would overwrite my mirrored CSF v15.01 version?
@eva2000
From my test, It's just same logics as CSF it self doing, download the source, extract, and execute "install.sh" to update.
So your customize source code might be rewritten
If you have many customize the source code outside "/etc/csf/" , just disabled it from custombuild.
@eva2000
Looks like it's already disabled?
Bash:
cat /usr/local/directadmin/custombuild/options.conf | grep -i csf
csf=no
Bash:
./build
Install/update server components
  da build awstats                                   # disabled by options.conf
  da build csf                                       # disabled by options.conf
  da build dovecot_fts_xapian                        # disabled by options.conf
So installed my CSF v15.01 version :)
Bash:
csf -v
csf: v15.01 (DirectAdmin)
csf -u
csf is already at the latest version: v15.01
Looks like this update somehow broke the ModSecurity interface. Advanced Features -> ModSecurity shows this message:
  • Like
Reactions: fln
I'm running Ubuntu 24.04 and updated to 1.683 last night, Mod security is ok here for me on admin and user panels?
Don't know, I just updated da and did a version update and it's still yes. However, I did upgrade to 15 before the DA update, don't know if that makes any difference.
Same over here. But updated after DA update.
Hm, you're right. It seems to be working for some accounts, but not for others, on the same server. I got three reports in a row, so I assumed it was a general issue. I tried to remove the modsec_audit.log which did not help. There is no indication of any error in any logs, and I didn't see anything special while running directadmin in debug mode. It happens on servers both with Apache and Litespeed.
It does seem like a general issue actually, and it is related to 1.683, but it's not affecting all users.
On one of our servers where this happens, I tried to downgrade DA to 1.682 a96573edc6aa43ea1753ca4694779a3ac5254598, and the error went away, ModSecurity loaded like usual. When I upgraded back to 1.683 c74812386392d0540785cf432941ae820fb0ad1b the error appeared again.
Edit/update: It seems the error only happens for the "main domain" on an account, if the account has multiple domains.
any update of this??
since version 1.682 the date of overwritten files is not updated in File Manager, but the correct date appears in FTP.
i attah capture of file manager and ftp, same folder, same files but filemanager doesn´t update the date after overwrite file
We aware that issue and developers are notified. It happens only for domains which have subdomains created ... HotFix will be released ASAP.
If I look in the controlpanel (custombuild) I don't see any updates (legacy and new), but if i run 'da build versions' I do see updates (that also can be installed with 'da build update_versions'.
I recommend creating a ticket and provide SSH access to your DA server to check the situation closer to understand the reason of that issue there.
