Solved Nginx Unit not listed
Daniel-Doggy
Hello everyone,
I am trying to get Nginx Unit to show up but for both my admin user and normal user, it is not listed under advanced features after install.
Have followed this doc to enable and install Nginx Unit.
But now that it is installed, it is still not listed under the advanced features section.
I have already checked that both the admin user and the normal user have Nginx Unit enabled on the account. (Both account have it enabled.)
My server also has a personal plus license and thus has the Pro Pack feature included.
So I am wondering what I still need to do (or what i missed) to get this to work.
And help is really appreciated.
Is there any chance that you customized an appearance of the skin on your server? Will you find Nginx UNIT if you use a search bar in Evo skin?
No, directadmin is just freshly install before enabling and installing Ngix Unit.
So I would not expect it to be a skin issue.
It exists in User level only
I managed to fix it.
It is an permission problem.
If you enable and install Nginx Unit, then DirectAdmin will display in the admin user management that is is enabled for both existing users and packages.
This is however not the case.
To fix it, uncheck the Nginx Unit by all users and packages, then wait 1 minute and enable it again.
After 1 minute it now should show up in advanced features.
In my case, Nginx Unit does not show anywhere, even after successfully installing. It doesn't show in the User Packages options or anywhere in the control panel.
Been trying everything for about 2 hours already.. going to open a ticket in 10 mins if I don't get any further with it.
