ConfigServer shutting down as of 31st of August 2025
BE AWARE! download.configserver.com has address 94.130.90.175. The IP is already taken and another website is hosted on the IP. SSL/TLS certificate is of course invalid, but they might place a download file there.
Just found a few more IPs, to delete from csf.allow:
94.130.90.175 # download.configserver.com
54.36.165.115 # download2.configserver.com
66.165.246.166 # license.configserver.com
2604:4500:9:156::6 # ipv6.license.configserver.com
Good catch. If the ips are whitelisted unconditionally, then they should of course be removed from csf.allow.
My alert is about the domains which still resolve and might contain infected software available for download. I would expect them to stop resolving of their download domains.
I've never seen those IP addresses in csf.allow before, i've only got my personal IPv4 & 6 listed and the softaculous server IPs. I will however pop those IPs in my csf.deny file though, cheers 😁
Big oof! Just found this out now (as I wanted to post a message here with some questions). I did not really noticed this before and I was still on the old version. Made sure to 127.0.0.1 the download urls and just updated DA to the latest version so it should get a non-scary version of CSF.
In the DA release notes I only see that csf is updated to v15 but nowhere what is changed in that regard. Does anyone know?
Not sure what you're asking here, but if it's about version 15.00 , that's the base version number way to the web gave CSF when they released it into the public domain with GitHub and a GPLv3 licence so anyone can update it, change it or fork it. Not sure yet, but wouldn't be surprised if DA have their own copy of it to develop and will integrate it further into DA. At least this way, it can be fully customised by anyone and the source code is available to keep an eye on security holes.
Ah thanks! I thought v15 was already an updated version provided by DA. So I should still turn off de auto update in any case. Thanks!
Yes, turn off the auto update. Safest way I would suggest is install it via custombuild as DA have looked at it and have made v15 safe for users, and turned off the auto update feature. Also, and more importantly as another member said yesterday, the download servers IP addresses that belonged to CSF now resolve to other servers so 100% not safe at moment and way to the web obviously haven't removed the records from their DNS.
I noticed the csget script in /etc/cron.daily still runs. I've checked the code, and it seems to ignore the AUTO_UPDATES = "0" setting. It only relies on a hardcoded array, which is now empty. Should we be deleting this script or leave it there for future updates ?
How can I find out what changes were made in versions 15.01 and 15.02?
From csf/changelog.txt
15.02 - Revert to TESTING=1 in the default config
15.01 - Update LFD faied login detection to be compatible with Dovecot 2.4
        Update default csf configuration for DirectAdmin installations
        Update csf.c wrapper to be compatible with modern gcc
15.00 - Changed license to GPLv3
I run these commands to disable auto-updates:
Also possible, disabling auto_updatese in csf.conf and restarting csf will remove that cron automatically for you.
However this still does not remove the csget cron in /etc/cron.daily which the question is about and is still running every day. It only does a version check on the old url, but still...
Personally I think it can be deleted, but I don't know if that would create difficulties with version checks when DA is updating CSF. Probably not as it does not make any difference now either. So imho that csget cron can be removed.
I had purchased CXS with a license. But if I change the server, I won’t be able to use it anymore. I’m really upset about that.
Hi, I am a bit confused and worried about all off this.
I was retiring from server-management, but I need to get one up and running again. :cry: (And as a simple programmer, I am NOT good at it)
For years I trust(ed) DA and everything that comes with it, and the CSF plugin is shipped with it.
Can you please give advice about what to do, or even better: provide a script (in custombuild) to make it safe again or replace it with an other firewall. Or whatever.
But at the moment in DA is no warning that CSF (plugin) can give any problems or leaks. And being a firewall.....
Thanks in advance, flexJoly
