DirectAdmin 1.687
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.687.
DirectAdmin 1.687
Hi, "Copy-To" feature in the File Manager don't show the button when select only one file, it's show when select multiple files.
IPv6 input in Multi Server validation still broke,
Also error messages and input boxes appear at the far left now. Is this a feature or is something broken in the CSS?
1. IPv6 for MSS - confirmed.
2. The issue with boxes - is not confirmed on test DA servers. Please provide some additional details:
- exact OS and its version;
- exact browser and its version;
- any other useful information.
Thanks for replying @romans , Ignore that one (From me, at least) as i've got a bit of custom CSS styling that was conflicting with a change that was made. All sorted now
Apologies if that caused you guys any issues.
Is anyone here using the Comodo ModSecurity rules for Nginx? Could you please confirm whether you’ve been able to update to the new version 1.236?
The update appears as available, but when I click to install it, I get the following message:
Installing Comodo Rule Set for ModSecurity...
Updating to latest CWAF client version
current version is up to date
update process finished!
download_cached: using cached '/usr/local/directadmin/custombuild/cache/cwaf_rules_nginx_3-1.236.tgz' file
patching file 30_Apps_OtherApps.conf
Reversed (or previously applied) patch detected! Assume -R? [n]
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file 30_Apps_OtherApps.conf.rej
Defaulting to Comodo WAF SecDefaultAction...
Reloading nginx service
Reloading apache service
Installation of ModSecurity Rule Set has been finished.
The issue is that the update remains available even after completing the process—it doesn’t seem to actually apply.
Yes, it seems the version of Comodo MS RuleSet is not updated properly in this file, if it exists:
/usr/local/cwaf/rules/rules.dat
Developers are notified to check it closer.
Thanks for the reply!
I can confirm that the file /usr/local/cwaf/rules/rules.dat does exist, and it only contains the text 1.233.
Should I make any manual adjustments to fix this issue, or is it better to wait for a future update that addresses it automatically?
Theoretically, you can remove that /usr/local/cwaf/rules/rules.dat file and re-run this command to re-create it with the new version:
da build modsecurity_ruleset
and after that the new version will be set correctly there.
But in any way developers need to check it closer if it is the only thing that was not OK there.
My customers reporting issues with on / off ModSecurity function (also it is working and blocking) but they do not see what
  • Like
Reactions: fln
