Services (Exim, Dovecot, LFD) start automatically after DirectAdmin update even when disabled
Can
I’m running DirectAdmin on AlmaLinux with LiteSpeed and Imunify360.
I have stopped and disabled Exim, Dovecot, and LFD, since I use external mail (Namecheap):
systemctl stop exim dovecot lfd
systemctl disable exim dovecot lfd
I also edited the file:
/usr/local/directadmin/data/admin/services.status
and set the following values:
exim=OFF
dovecot=OFF
lfd=OFF
However, after every DirectAdmin update, Exim and Dovecot become active again and start running automatically —
even though they are disabled in both systemd and `services.status`.
Only LFD stays stopped as expected.
It seems that during updates, the DirectAdmin update script or service monitor automatically re-enables these services.
Is there any way to prevent Exim and Dovecot from being restarted or re-enabled after a DirectAdmin update?
Thank you,
Can
  • Like
Reactions: Can
disable at custombuild option too. Otherwise when available update, it's will restart/start again.
The issue was caused by CustomBuild automatically re-enabling mail services after updates.
To fix it, I only changed the CustomBuild options — no manual systemctl commands were needed.
I went to:
Admin → CustomBuild → Edit Options
Then I set the following options to “No”:
  • exim
  • eximconf
  • clamav_exim
  • dovecot
  • dovecot_conf
  • csf
After saving, the services no longer start or get reinstalled after updates.
Problem solved. ✅
Thank you.
