DirectAdmin 1.690
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.690.
DirectAdmin 1.690
This sounds like a PHP warning, not a CB related thing.
Maybe you are using some PHP extension that is not compatible with the opcache or so?
@Active8, you can see it in action externally with:
$ curl https://domain.on.your.server.com/test.php
$ ps -elfH
4 S user    1059766       1  0  80   0 -   894 do_sys 14:18 ?        00:00:00   bwrap --symlink usr/bin /bin ...
4 S user    1059769 1059766  1  80   0 - 23499 do_epo 14:18 ?        00:00:00     php-fpm: master process (/usr/local/directadmin/data/users/user/php/php-isolated-fpm74.conf)
1 S user    1059771 1059769  5  80   0 - 27311 skb_wa 14:18 ?        00:00:00       php-fpm: pool main
The bwrap process will be a parent of the php-fpm process.
Internally it can be tested by creating a PHP script that reads explores files on the server. Example:
$ cat /home/user/domains/example.com/public_html/isolation-test.php
<pre>
<?php
    echo "/var contents:\n";
    print_r(scandir('/var'));
    echo "/home contents:\n";
    print_r(scandir('/home'));
</pre>
$ curl example.com/isolation-test.php
<pre>
/var contents:
Array
    [0] => .
    [1] => ..
    [2] => lib
    [3] => run
    [4] => tmp
/home contents:
Array
    [0] => .
    [1] => ..
    [2] => user
</pre>
The same test in normal PHP-FPM would not work because of basedir restriction. In isolated FPM the basedir restriction is no longer needed and present because user can only explore the jailed environment.
But I see it just using da build versions..........
I do compile the imap extension, even though it gives a ton of warnings when compiling....... Maybe I should ditch it, doubt it's being maintained, nor the issue!
Note: The isolated FPM is activated only for the user accounts that use jailshell (the Jailed check box in the user configuration page).
This is not available for legacy license right ?
Correct, it does not work for Legacy Licenses.
I can confirm this error under openlitespeed. /webmail gives 404
I myself did not have OLS installed on test DA server. But I switched to it and built OLS. As result /webmail works fine after that.
If the rebuilding does not help, please try checking if you do not have any OLS customization.
Yes thanks, it helped me too, just edited previous post.
Hi, sending mail with smtp tls ssl on poort 587 stopped after this update (almalinux8)
Fix:
da build exim
da build exim_conf
I am getting the error "User's System Quotas set
Some actions have failed. Please check the server error log for more details." when changing the configuration of a user account after upgrading to 1.690. Please guide me how to fix this error
Also problems with suspending and unsuspending users. It gives the error "Some actions have failed. Please check the server error log..."
After f5, it works, but these are not comfortable warnings from DA.
@cautroi, @toktokcity, please open a support ticket. This will give us a chance to check out the reason for the errors.
This DA release treats some previously ignored warnings as errors. More details about the error should be in the service logs.
Thanks.
A new build for this DA version is released. It includes the following fixes:
  • Added compatibility code to avoid having to rebuild openlitespeed right after update. Thanks @toktokcity and @johannes.
  • Fixed the surplus error message when modifying user. It was caused by failure to disable per-user redis service on servers where per-user redis is not used at all. Thanks @cautroi and @toktokcity.
  • Fixed protected directories page, to allow selecting sub-directories.
  • Enabled PHP plugin imagick to work with PHP 8.5.
Thanks everyone.
