- Feb 27, 2003
@Richard G is correct . MariaDB 10.5 is EOL, and while AlmaLinux promises support until 2032, that doesn’t mean they’re on the hook for fixing everything. They’ll backport critical updates if MariaDB releases them, but beyond that, AlmaLinux’s support is limited. They’re not legally required to patch every vulnerability or fix every issue, so relying on this isn’t the same as using actively supported software.
As for @virtio (the thread starter), their point really hasn’t been addressed yet. The issue wasn’t about our sustainability choices, but how we went about them. Referring to the codebase as "legacy" without offering a clear roadmap was a huge pain-point, especially for large-scale operations.
When you’re dealing with big infrastructure, "maybe" or "you might get more" isn’t enough to make decisions on. It could even get you in hot water with regulators. @virtio we more than accept the premise of your post and thank you for your professionalism and willingness to see things from our side. In return for that, we will do the same, and publicly admit you could of called us "amateur hour" and been justified in doing so. Thanks for being a class act.
