DirectAdmin 1.690
You need to remove dnssec-enable yes; from named.conf, which is no longer supported and can cause problems when starting named.
We do not use outdated software like DirectSlave but simply a BIND or PowerDNS cluster. Also something to consider rather than waiting for a developer from Ukraine.
It's decreated as from Bind 9.16 but was still working. It was fully removed from 9.18.
Anyway I can confirm it's a 1.690 issue as also with the other server on 1.689 it works flawlessly with creating and deleting.
But on changing records it does not. So might still be something else.
Regarding the DNS cluster.
The only difference between version 1.690 and 1.689 is that cluster API calls (from main DA server to cluster servers) now adds Content-Type: application/x-www-form-urlencoded header. This affects requests to delete DNS zone and request to add record.
This header correctly describes the request body (URL encoded data). We are adding this header to make cluster calls compatible with servers that automatically decode the request payload based on the content type header.
@Richard G could you please test out a special DA 1.690 build d32f210f685650153589cc0db66d7a1d2cb1dae3. This is the identical build to the normal DA 1.690 but it does not add the new Content-Type header in DNS cluster related API calls. If this build works correctly with directslave tool it would mean addition of the correct Content-Type header causes problems for directslave and explains why it stopped working correctly with DA 1.690.
The addition of correct Content-Type header should have no effect on well-behaving HTTP servers, and it should improve compatibility on servers that actually use this header for content parsing.
Thank you for checking the difference for us.
I just had time to check special DA 1.690 build version you suggested and I can confirm that with that special version, everything in Directslave is working as designed again.
Creating domain, adding records and deleting domain is working again perfectly with that special version.
Before the update, all I needed in my custom httpd was:
|?USER=webapps||?GROUP=webapps|
PHP-FPM ran under the webapps user. After the update, I had to add:
|?PHP_FPM_SOCKET_PATH=/usr/local/phpXX/sockets/webapps.sock|
Hi all!
I'm still alive and doing relatively well, still supporting DS and my other projects.
I'm already working on a new compatible version of DirectSlave.
Hi all!
Amazing Thank you!!! Much appreciated as I love your software 🙏
I read a message earlier saying you needed access to some servers for testing? I can't give you access to mine, but I can give you a few servers for you to use for testing if you need?
Thanks @roman_m. We are planing to make a new hot-fix release that removes the header again as a temporary solution. However, the fix inside DS should be simple. Once new DS is released we would add the header back in to keep DA cluster requests aligned with the HTTP spec.
@roman_m published a new version of DS earlier to address this I think. It's on the other thread @fln. I'm going to take a look at it tomorrow.
I hope so... For some reason the special version @fln gave me does not stay either unfortunately. Somehow it gets automatically updated to the normale 1.690 version on both servers, while autoupdate in directadmin.conf file is off.
Tested on DirectAdmin 1.69 on Debian 13.
Are you sure you updated correctly to 3.5.1? Enable debug (debug 1) in directslave.conf and email me error.log content.
My bad, sorry!
I was too enthousiastic and so thus fast. I overwritten everything and forgotten that I renamed the longer binary name to just directslave, so the older version was started again.:rolleyes:
The 3.5.1 is working perfectly. Thanks a million @roman_m for fixing it!! (y) (y)
So, we have proof that DS 3.5.1 is fully compatible with DA 1.69. It is also backward compatible.
