plz dont beat me to post here some AI answers on this topic ..
Difference Between mbox and mdbox
Here’s a clean, technical comparison of the two mailbox storage formats, especially as used in
Dovecot.
Core Idea
- mbox = one single file per mailbox folder, all emails stored sequentially inside it.
- mdbox = Dovecot’s modern format, storing multiple messages per file, distributed across several files for each mailbox.
Comparison Table
| Format | Structure | Performance | Reliability | Storage Efficiency | Best Use Case |
| mbox | One large file per folder | Slow with large mailboxes | Vulnerable to corruption | Inefficient with many small emails | Legacy UNIX systems |
| mdbox | Multiple messages per file | Very fast (index‑optimized) | Robust due to Dovecot indexing | Highly efficient | Modern Dovecot installations |
Technical Details
mbox
- Stores all messages of a folder in one big file.
- Any change (delete, move, append) requires rewriting parts of the file.
- Performance degrades heavily as the mailbox grows.
- If the file becomes corrupted, the entire mailbox folder is at risk.
- Very old, traditional UNIX format.
mdbox
- Part of Dovecot’s dbox storage family.
- Stores multiple messages per file, but splits them across several files.
- Uses Dovecot’s index files for extremely fast access.
- Much more efficient for:
- large mailboxes
- IMAP usage
- backups
- servers with many users
- More resilient to corruption — only small chunks are affected, not the whole mailbox.
When to Use What
Use mbox only if you absolutely must
- Legacy systems
- Compatibility with old tools
- Not recommended for modern mail servers
Use mdbox for modern setups
- Dovecot servers
- High‑performance IMAP
- Large or growing mailboxes
- Efficient storage and fast indexing
Summary
mdbox is superior to mbox in almost every way: faster, safer, more efficient, and designed for modern mail servers.
mbox is essentially a legacy format that persists only for compatibility reasons.
Here is a
clear, safe, step‑by‑step explanation of how to migrate from
mbox → mdbox in
Dovecot, written so you can follow it without surprises.
This is the
officially recommended migration path used by most modern mail server admins.
Below is the standard, safe, supported method using Dovecot’s built‑in migration tools.
1) Before migrating, you need to add mdbox as a new storage location, but keep mbox active so Dovecot can read from it.
Edit your Dovecot config (usually
mail_location = mbox:~/mail:INBOX=/var/mail/%u<br>mail_home = /home/%u<br>
Change it to:
mail_location = mdbox:~/mdbox<br>mail_home = /home/%u<br>namespace inbox {<br> inbox = yes<br>}<br>
But
do not remove the old mbox settings yet — you will still need them for the migration command.
2) For each user:
mkdir /home/USERNAME/mdbox<br>chown USERNAME:USERNAME /home/USERNAME/mdbox<br>chmod 700 /home/USERNAME/mdbox<br>
3) Dovecot includes a built‑in command to copy mail from mbox → mdbox:
doveadm -Dv backup -u USERNAME mdbox:~/mdbox<br>
What this does:
- Reads the user’s existing mbox mail
- Writes it into mdbox format
- Preserves flags, folders, and indexes
You can run this for all users:
for u in $(doveadm user '*'); do<br> doveadm -Dv backup -u "$u" mdbox:~/mdbox<br>done<br>
4) Once migration is complete and verified, update your config:
Remove or comment out the old mbox settings.
Then reload Dovecot:
systemctl reload dovecot<br>
5)
Use:
doveadm mailbox list -u USERNAME<br>doveadm fetch -u USERNAME 'hdr.subject' mailbox INBOX<br>
Check:
- All folders exist
- All messages are present
- Flags (Seen, Answered, etc.) are correct
6) After you confirm everything works:
rm -rf ~/mail<br>rm /var/mail/USERNAME<br>
But
only after backups.
7)
mdbox benefits from Dovecot’s index optimizations:
mail_prefetch_count = 20<br>mdbox_rotate_size = 2M<br>mdbox_rotate_interval = 1d<br>
This keeps mdbox files small and corruption‑resistant.
Migrating from mbox → mdbox involves:
- Preparing Dovecot config
- Creating mdbox directories
- Running doveadm backup
- Switching mail_location
- Verifying
- Cleaning up old mbox files
mdbox gives you:
- Faster IMAP
- Smaller storage footprint
- Better reliability
- Faster backups
- Less I/O load
