Richard G
It does, see your other thread. Just checked it, but found a little version issue.
I guess you are talking about the PHP version summary table, which is forced to be sorted on number from low to high.@tlweb I found a little bug which was also in the original plugin.
When one changes php versions, for example current situation:
php1_release=8.1
php1_mode=php-fpm
php2_release=8.2
php3_release=8.3
(or any other versions) and we want to swap the first PHP version to a new version as DA uses this for default.
Then it would become for example:
php1_release=8.3
php1_mode=php-fpm
php2_release=8.2
php3_release=8.1
After doing this, everything is updated, except for the PHP version list which still shows the old order, so still shows php 8.1 on top as first version, while that should have been changed to php 8.3.
So I guess it need some check to keep the release versions in the correct order, right?
Yes, then I probably got lucky that I had them from low to high in the beginning, didn't notice that.I guess you are talking about the PHP version summary table, which is forced to be sorted on number from low to high.
