Can't perform FTP Admin Backups after upgrade
plantheo
Ezeiza, Argentina
Hi guys!
I'm having a hard time trying to get my Admin Backups back to work. I'm currently using a remote FTP server as my endpoint.
Most funny thing is that it was working fine before one of the latest updates. My current DA version is #1.643
This is the error message:
User admin has been backed up. <5:07:19>
ftp_upload.php exit code: 28
ftp_upload.php output: curl: (28) Failed to connect to [endpoint here] port 21 after 254979 ms: Connection timed out
curl return code: 28
<5:11:34>
Please see this URL and check for curl exit code '(28)': https://help.directadmin.com/item.php?id=2127
Although a backup error has occurred, the upload of valid backups would have still been attempted to [endpoint here] <5:11:35>
I also have a System Backup up and running with no issues. Both backup jobs are pointing to the same FTP server and the exact same port.
¿Any clues?
How big are those updates? It might be just a coincidance that the update and this error occurs within the timeframe of some updates.
The amount of MS is 4 minutes. If you have a big backup, maybe the creation of the backup and next transfer might take longer.
Thank you Richard. Yes, the backup is pretty big indeed. But I can't understand why it was working and now I have this kind of error.:cry:
It might be it has grown a bit more and then it might just be past the timeout. Can you increase the timeout and try again?
and now it hit me with these error msgs on a new AlmaLinux 9 server.
Its only on the "big" accounts of 7GB+ that I get this error.
Local backups to admin_backups work fine, so its just a matter of disconnects on the FTP.
Question is,. is it getting disconnects on the Sender or the Reciever side.
After what I'm guessing is a timeout, the backup continues to the next account.
Maybe I need to change it to SFTP? maybe that will be prevent that problem?
Well, I just let it run,. will update after few hours to see the results :)
It's external FTP server issued.
Try manual curl to run FTP upload file, the result should be same with directadmin process.
