DirectAdmin 1.693
@exlhost
I’m running on Almalinux 8.10 with DirectAdmin 1.693, and I’ve already updated MariaDB and run da build all.
I’ve noticed an issue: whenever a customer (or anyone) changes the PHP version inside DirectAdmin, all the sockets under /var/run/php-fpm — along with the directory itself — suddenly disappear. This results in websites showing Service Unavailable because there’s no socket available.
I’m not sure if this is happening only on my setup or if others are experiencing the same behavior. Have you encountered this problem?
@anas_xrt
The php version change takes ~1 minute because web server configuration is reloaded with taskq (it gets executed once per minute).
Hey Fin, thanks for the release!
I think there might have been quite a major change to letsencrypt.sh with the addition of the internal_request() function in v1.693 ? But I couldn't see it in the release notes....
As far as i can see DA is now calling that function internally from the SSL commands, so anyone using a custom letsencrypt.sh that doesn't handle internal_request is now broken.
Also the log files might have moved to acme_provider_cert_logs and are no longer in errortaskq.log? Unless it's just our lab setup that's gone wrong, which is entirely possible...
The update seems to have a weird influcence, perhaps intended, when users click on phpMyAdmin to login on their database. Normally the user that logs in is the database user/owner. Now it's the accountname_long series of random characters@localhost. This causes issues with the ownership when they run certain queries, like: "Error 1227: Access denied; you need (at least one of) the privilege(s) for this operation".
The users are not aware of the 'weird' login. The workaround is: logout of phpMyAdming and login again with the correct credentials.
Is this on purpose and if yes, why?
Is there a way to fix this?
Thanks @deltaB. The change-log is updated.
Our long-term goal is to allow main DirectAdmin service to issue certificates without the letsencrypt.sh script. The new letsencrypt.sh script subcommand is a transient step, allowing us to restructure everything in smaller steps. The structure and parameter of this new sub-command is not stable and will change with each new DA release.
This sounds like a great improvement. I assume one of the goals will be to have a unified view of requests and the outcomes in the UI? There's currently no way via the UI/API to ask the status of a SSL request AFAIK.
I know, I know, "You still use 5.7?!", even though it's harmless, is there a way to suppress this message and still be able to upgrade other software?
NB. I can update things within DA, but not via the command line?
NB 2. Can't even update some software, even in DA.
Can I even set it at 8.0 and not upgrade to 8.0?
Yes
Yes, the new version is expected today, I am very curious about the unbound DNS.
Indeed, just tested it too. I noticed that after running:
da build set unbound yes
da build set unbound_as_default_resolver yes
da build unbound
/etc/resolv.conf automatically updated with nameserver 127.0.0.253 instead of adding it to /etc/resolv.conf yourself as indicated in the DA changelog.
Yes that is added later, in the beginning you had to do this manual, there was some concern about settings after reboot (normally only changing resolv.conf is not enough because after reboot your values are changed back)) but its fixed now
@exlhost I prefer update bind with version 9.16 and use for HTTP3 with HTTPS record, for unbound I use for spamd dns resolving cache only.
my services monitor is broken i'm running on the latest directadmin updates ...
nothing in directadmin error log
