DirectAdmin 1.697
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.697.
DirectAdmin 1.697
The connection_info_sh script is now showing only the internal IPs instead of the external ones that are in the next column $6 (instead of $5). And can you please remove the [ and ] around the IPs? It makes it easier to copy them.
  • Like
Reactions: fln
Thanks for catching this @JosKlever. A new release is pushed out with next column fix and removal of the square brackets for IPv6 addresses.
Today I noticed internet.nl checks on some da servers dropped from 100% -> 98% due to insufficient secure parameters for the Diffie-Hellman stuff. Is this going to get updated/fixed in da update?
There should be no changes regarding TLS configuration in this release. We would need more details to follow up on this. I think it is unlikely to be related with DA update. If we can improve the default TLS configuration it would be a nice update for the upcoming DA release.
There should be no changes regarding TLS configuration in this release. We would need more details to follow up on this. I think it is unlikely to be related with DA updated. If we can improve the default TLS configuration it would be a nice update for the upcoming DA release.
I didn't mean it's related to the da update, it isn't. Just noticed the ssl settings are getting 'old', so maybe something to keep in mind for the next update.
  • Like
Reactions: fln
Hello.
I didn’t notice on which version the delete user button disappeared. It was when searching for a user (on View User page), near the login buttons under the name, reset password and others. At first it disappeared from the admin (although the admin must have it, he should be able to delete any user), but was saved from the reseller. Now the reseller doesn't have it either. Are these problems with the skin, cache, or was it really removed for some silly reason?
Standard theme..
Hello.
Standard theme..
Now for resellers "Delete" button is available only on the page like this:
https://[HOSTNAME]:2222/evo/reseller/users
By default it is inactive and you can click it only when you select (set a tick) for the user(s) which you want to remove.
The similar situation is for "admin" user here:
https://[HOSTNAME]:2222/evo/admin/all-users
