removing old PHP scripts is not working
Audrey
Hi
I am trying to remove old PHP scripts from this server.
I have done the following
1. Login as admin as admin.
2. Go to CustomBuilds.
3. Click on Edit options.
4. Set php1_release to version 8.5.
5. Set the rest of php_release to no.
6. Click save.
Then
in SSH I ran
./build php n
./build rewrite_confs
Then I ran
./build list_removals
and SSH says
"If you want to remove all the suggested programs above, run: da build remove_it"
There are no items listed for removal so I did not run
da build remove_it
I know there are lots of old php scripts because the DirectAdmin admin section wants me to update the old php scripts on a regular basis
Please advise
Audrey
What do you mean under "PHP scripts" ? If I understood you correct, then you want to disable and remove all old PHP versions except the latest one and you want only using PHP 8.5 on your DA server. If I am right then, you can run these commands (just in case):
da build set php9_release no
da build set php8_release no
da build set php7_release no
da build set php6_release no
da build set php5_release no
da build set php4_release no
da build set php3_release no
da build set php2_release no
da build set php1_release 8.5
then re-build php:
da build php
da build rewrite_confs
It is should be enough. If "list_removals" shows the results like this one
[root@serv ~]# da build list_removals
If you want to remove all the suggested programs above, run: da build remove_items
[root@serv ~]#
then it is OK and you do not need anything else, because there is nothing to remove
Thanks for your help
I already have all of the old versions of PHP set to no in the admin section.
When I run the command in SSH
it says
php2_release is already set to no
I know there arestill lots of old php scripts because the DirectAdmin section wants me to update the old php scripts on a regular basis
Attached is a screenshot of DirectAdmin wanting me to update these packages.
This screenshot if from hours after this was posted
You are using CloudLinux OS and have installed PHP that comes from CloudLinux too. In that case please reach CloudLinux support to get more details how to correctly deal with those packages.
This server is using
Operating System: AlmaLinux 9.8 (Olive Jaguar)
CPE OS Name: cpe:/o:almalinux:almalinux:9::baseos
how do you get that package installed ? Directadmin not install from the OS package, it's compiler using custombuild.
Except like cloudlinux will install those package
maybe it's installing by VPS provider ???
This is a dedicated server. I installed the OS from this server's main control panel. Then I installed DirectAdmin via SSH command.
You might try and run (then command will first list packages w/out actual removing them):
yum remove alt-php*
DO NOT hit 'y' when asked.
You might first review the list of dependent packages and unused dependencies, which are offered for a removal.
Bash:
Is this ok [y/N]: n
Operation aborted.
If you are 100% sure you don't break the things, hit 'y' to proceed with a removal.
p.s. You might post an output of the command here (without proceeding to a removal), if you are hesitating...
Thanks for your help.
I ran yum remove alt-php* about a week ago and , so far, I have not received any more update old php scripts since then - hooray.
Thanks again
Take Care
