All sites on the same servers are hacked with their own self-recovered files
shanky
All DirectAdmin servers have root login with SSH keys. I found that many virus files are spreading to all DirectAdmin accounts and all vps & servers.
An undead malicious file that will rebuild itself when deleted.
-rw-r--r-- 1 xxxx xxxx 374 Sep 12 12:10 accesson.php
-rw-rw-rw- 1 root root 10676 Sep 3 03:23 c5eXWE9oxH.php
Whenever I delete a lot of virus files, the deleted files will be undeleted in a few seconds or minutes.
The virus files are created and spread to all users very quickly, and the worst are all user accounts, even the "Admin".
If the Directadmin staff want to investigate, I can send all ssh passcode key details privately.
This is an extremely urgent case; please help.
Well that sucks as normal useraccounts can't create files with those permissions (rw/root). This is a root compromise. I wouldn't even start cleaning that server but reinstall a clean one with heavily rotated credentials. Unless you have installed something like AIDE you'll never know what really changed outside userspace.
If you want to find out how it happend check all crontabs of all users, DA's customhooks, authorized_keys files, ld.so.preload stuff. Check for running but deleted processes with lsof. Use rpm toch check for changed systemfiles.
As you have root logins with ssh keys and it happened on all servers, check your jumphost or the system you use to login to the da servers. But a cleanup can take days without a clean baseline. Better reinstall and restore safe backups. At least from a decent time before sept 3.
Directadmin staff normally don't investigate hack issues so you would have to be very lucky.
Additionlly to what Sysdev already said, start installing Maldetect (click) and scan all accounts. Often malware which starts itself again is coming from leak scripts or leak wordpress themes and kindlike things and addons.
Also be sure Openbasedir is on and php safe mode is on in Directadmin itself for the domains.
However, if all vps and servers are infected, then the issue might be bigger, start with the tips from Sysdev!
In your case, I suspect one of two things happened.
  1. Less likely, but possible: the workstation that holds your private key was compromised, and the key had no passphrase, a weak one, or one you reuse elsewhere. I don't think this is the cause, but I can't rule it out. One thing worth being careful about: if you need to give someone SSH access, make sure you are actually talking to the vendor's support channel and not to whoever replies in a public thread. When they confirm, ask them for their public key and for the IP they will connect from (useful if you have an IP allow list on SSH). Add that key to the account, grant sudo only while they need it, and remove the key, the sudo rights, and the IP entry once they are done. That way they connect with their own key and passphrase, and you never handle anyone's private key.
  2. More likely: something in the hosting stack got exploited and then escalated. The usual chain is an outdated CMS or plugin on a customer account, a web shell dropped there, and then a local privilege escalation to root through an unpatched kernel. That would explain both files you posted: one owned by a user, one owned by root. A few questions worth asking yourself. Are your kernels patched, and did you apply the available mitigations in the window before the patches landed? Do you monitor whether customers keep their sites updated? Do you scan customer accounts for known malware and signs of compromise, both routinely and after a major CMS or plugin vulnerability, and do you actually act on the findings (clean up, and have a conversation with the customer)? If the answer to most of that is no, that is very likely where this came from.
On the files themselves: if a file comes back within seconds of deletion, deleting it is not the fix. Something is still running. Look for cron jobs (user crontabs, /etc/cron.*), systemd units and timers, .bashrc/profile entries, and any process still running as the affected users or as root. Check lsof and ps around the moment a file reappears, and check your web server logs for the request that triggers it.
But be honest with yourself about the bigger picture. You have a malicious file owned by root. That means root is compromised, and once that is true you cannot trust anything on that machine, including the tools you are using to investigate it. The only reliable path is a fresh install on new storage, restoring only customer data after scanning it, with all passwords and keys rotated. Cleaning up in place will almost always leave something behind.
At one DirectAdmin server I found base64 encoded user cronjob something like:
/usr/bin/pkill -0 -U1072 defunct 2>/dev/null || SHELL= TERM=xterm-256color GS_ARGS="-k -liqD" /usr/bin/bash -c "exec -a '[kstrp]'" 2>/dev/null
How it is possible to add such cron command, if Cronjobs is disabled for user at DirectAdmin? :)
Disabling cronjobs in Directadmin just does that. It does not disable or stop the whole crond service.
So if something would be able to add the correct commands via a shell (hack scripts can do that too) to make a cronjob, this is also possible.
But even worse, check post 4 from id14, I also think it's might be more likely that what he suspects is happening. System is rooted.
When disabled in DirectAdmin cronjobs can not be edited in the web panel only. They can still be created in a shell or by any other available mean. For example a PHP shell can be used to create a cronjob
DirectAdmin can add for example to cron.allow file only users, which have Cronjobs activated.
This is hacked Wordpress with malware, but SSH is disabled, PHP (fastcgi) open_basedir is activated, secure_php (disable_functions) is activated. How can I fully jail PHP to /home/username/ or best way to /home/username/domains/domain.com/? Because one hacked Wordpress will infect all user websites or important files in /home/username/
