DirectAdmin 1.713
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.713.
DirectAdmin 1.713​
Note: Automatic DA updates will only start on 2026-10-26 8:00 UTC (Monday).
Since abandoning sysbk problems with System Backup from DA 1.709 and upwards. See my earlier post about it.
Edit 1: It could be a problem with my ASUS RT-BE88U FTP target because the router's advertised TLS support seems incompatible with curl/OpenSSL FTPS negotiation. I've reported my findings on snbforums as well.
Edit 2 from snbforums:
FTP code 426 usually indicates the transfer aborted during an operation. Could be an unstable connection, a timeout, etc... Clients should treat it as a transient error, and retry the transfer.
Fixed it with:
cp -a /usr/local/directadmin/shared/sysbk.sh \
      /usr/local/directadmin/shared/sysbk.sh.bak
sed -i 's/ --ssl-reqd//g' /usr/local/directadmin/shared/sysbk.sh
Sysem Backup stopped working, System Backup script update.
An error occurred during the backup 9/27/2026, 10:57 AM
Starting System backup...
Prechecks:
  Sanity checks: ....curl: (64) Requested SSL level failed
<br>
Why? FTP does not need SSL.
Edit: I changed the FTP server to accept ssl (Enable TLS support), now this message appears:
Prechecks:
Sanity checks: ....curl: (21) QUOT string not accepted: DELE /Redacted/upload_test.txt
<br>
The file was uploaded to my ftp server, but as a security I don't allow deletion or read actions by FTP, only for myself as a local user.
Please skip the delete test and I'm happy with ssl ftp.
Edit 2: For testing purposes I gave R/W access to my ftp server. Now again another error appears.
Prechecks:
Sanity checks: .... Done
Free disk space: .... Done
Archiving:
/var/named
/etc/named.conf
/etc/openlitespeed
-> /backup/09-27-26/sysbk-09-27-26.tar.zst .... Done
Transfer:
/backup/09-27-26 -> redacted.net ....curl: (18) server did not report OK, got 426
<br>
Edit 3: Other observation. the backup file on my DA server in/backup/09-27-26/sysbk-09-27-26.tar.zst seems to be valid, the file uploaded to my ftp-server seems to be corrupt/incomplete.
Edit 4: After every failure the /backup directory is not cleaned up. When starting a new backup I get the message:
Prechecks:
Sanity checks: ....backup already performed for 09-27-26 (/backup/09-27-26), aborting...
<br>
Then I have to SSH to my server to delete the leftovers from the backup.
Edit 5: Backup and Restore still works fine.
The bug is only present in LiteSpeed 6.3.7-5. Since stable still uses LiteSpeed 6.3.7-3, it is not affected.
