AlmaLinux 10 support
In addition: if you had DA already installed you must execute
 build all d
command to rebuild after upgrade
Do I need to do a clean installation to move from 9 to 10, or is it possible to upgrade directly?
It is possible in most cases. In rare case you will be advised to install a new server, as your server might not support AlmaLinux 10.
  • Like
Reactions: Can
 build all d
My DirectAdmin setup is fully configured, and everything is ready.
Would it be okay if I used the following commands?
systemctl restart directadmin
systemctl restart lsws
imunify360-agent restart
./build php n
After upgrade from AL9 > AL10 ?
Sorry don't understand your question, why do you want to execute those commands ?
If it is after upgrade you don't have to because its then already rebuild with all the installed components anyway (da build all)
  • Like
Reactions: Can
Thanks for your response.
I asked because I wanted to make sure everything (DirectAdmin, LiteSpeed, Imunify360, and my custom PHP builds 8.3 / 8.4) would run smoothly after upgrading from AlmaLinux 9 to 10 using ELevate.
I understand that the upgrade process already rebuilds the core system with all installed packages, but since I have some manually compiled PHP versions and LiteSpeed integrations, I thought running:
./build php n
./build rewrite_confs
after reboot could help re-link PHP with the new system libraries just to be safe.
So, basically I just wanted to double-check whether running those commands after the OS upgrade is harmless or unnecessary.
The user Active8 posted a command which should be executed after an OS upgrade, see the post #22
Not only PHP but all software managed by DirectAdmin should be re-installed after the upgrade of a major OS version.
  • Like
Reactions: Can
Thanks both @Active8 and @zEitEr for clarifying!
Just to explain my situation a bit better — I’m running a personal DirectAdmin setup with LiteSpeed, Imunify360, and custom PHP builds (8.3 / 8.4).
Mail services like Exim/Dovecot/Rspamd are completely disabled, because my domains use external MX records (Namecheap).
The server is fully updated, CSF/firewalld disabled, and everything works perfectly on AlmaLinux 9.
My main goal after upgrading from AlmaLinux 9 → 10 via ELevate is to keep all configurations and integrations exactly the same, without doing a full rebuild of every component.
That’s why I was thinking of just running these after reboot:
./build php n
This should only recompile PHP and refresh configurations with the new system libraries — no reset, no configuration loss.
From what I understand,
build all d would indeed rebuild everything (including mail services I don’t use),
while build php n + rewrite_confs is enough to safely re-link PHP/LiteSpeed with AlmaLinux 10.
So I just wanted to confirm that in a non-mail, LiteSpeed-based personal setup, doing a light rebuild like this should be perfectly fine and safer than a full “build all d”.
Thanks again for your guidance — this discussion helped clear up the differences between “rebuild” and “reset” after an OS upgrade! 🙏
da build all respects options.conf and skips disabled services, no options.conf will be effected. Run da build options to see which services are enabled, and only they will be re-compiled with the command. It is not reset of DA settings. For resetting DA options.conf one can use another command, it was never offered by me here.
  • Like
Reactions: Can
Thanks a lot for the clarification, @zEitEr — that makes perfect sense now.
So the correct and safe approach would be:
./build all d
This way I’ll have the latest CustomBuild scripts before rebuilding,
and since build all d respects my options.conf (mail disabled, LiteSpeed and PHP enabled),
it will only recompile the active services without touching my configs.
I’ll apply this later today after the upgrade to AlmaLinux 10.
Appreciate your help — that explanation really cleared every
thing up. 🙏
I wanted to report several major issues I experienced while installing and using DirectAdmin on AlmaLinux 10.
These problems do not exist on AlmaLinux 9, so I believe DA is not fully ready for AL10 yet.
Below is a summary of the issues:
1. Redis cannot be installed (package removed in RHEL/AL10)​
AlmaLinux 10 repositories do NOT contain the redis package.
dnf install redis
No match for argument: redis
And CustomBuild also fails:
You cannot install Redis, because redis=yes is not set in options.conf file.
systemctl enable --now redis
Failed to enable unit: redis.service does not exist
Reason: Redis was completely removed from RHEL 10 base repositories.
DirectAdmin expects /usr/lib/systemd/system/redis.service to exist, but it is not available on AL10.
So Redis + LSCache Object Cache cannot be used on AL10.
2. Imunify360 extension loader error (i360.so)​
PHP produces continuous warnings:
PHP Warning: Unable to load dynamic library 'i360.so'
undefined symbol: _ULx86_64_init_local
This happens because the current Imunify360 builds also don’t fully support AlmaLinux 10 yet.
DirectAdmin enables the extension by default, causing PHP startup errors.
3. Firewalld is masked / disabled​
Fresh AL10 installations have firewalld completely disabled or masked:
systemctl status firewalld
Loaded: masked (unit firewalld.service is masked)
Active: inactive (dead)
DirectAdmin detects no firewall, and CSF/LFD also fails unless manually installed.
4. PHP config files not applied after rebuild​
Changing values such as:
  • memory_limit
  • max_execution_time
  • upload_max_filesize
Manually under:
/usr/local/php*/lib/php.conf.d/*
does not immediately reflect in DA panel or PHP info.
A full rebuild and service restart is required, unlike AL9.
5. Some DA CustomBuild components missing AlmaLinux 10 compatibility​
Examples:
  • Redis
  • Some PHP extensions
  • Imunify360 loader
  • Certain systemd unit files expected but missing
AlmaLinux 10 introduces many changes compared to AL9, and DA components are not fully adjusted yet.
Conclusion​
DirectAdmin on AlmaLinux 10 is not production-ready at the moment due to missing packages, incompatible extensions, and service management issues.
After testing, I had to revert back to AlmaLinux 9, where everything works correctly:
  • Redis
  • Imunify360
  • PHP extensions
  • Firewalld
  • CustomBuild components
I recommend holding off AlmaLinux 10 support until these compatibility issues are resolved.
Thanks.
I've got AlmaLinux 10.x with Directadmin running on a Hetzner VPS since Thu Aug 14 10:25:07 2025 (at least):
- DirectAdmin: 1.689 893e826690311d14b8e868ad3549278f64b477a1
- Kernel: 6.12.0-55.42.1.el10_0.x86_64
- OS: AlmaLinux 10.0 (Purple Lion)
- csf: v15.05 (DirectAdmin)
with the following options:
Nginx Unit: no
Apache: 2.4.65
ModSecurity: no
htscanner: no
Dovecot: 2.4.2
Dovecot configuration: yes
AWstats: no
Exim: 4.99
exim.conf update: yes
BlockCracking: no
Easy Spam Fighter: no
SpamAssassin: no
ClamAV: no
MariaDB: 11.4.9
MySQL backup: yes
MySQL backup directory: /usr/local/directadmin/custombuild/mysql_backups
MySQL compress backups: no
PHP (default): 8.4
phpMyAdmin: 5.2.3
ProFTPD: no
Pure-FTPd: 1.0.52
RoundCube webmail: 1.6.11
Replace "php.ini" with 'da build all' and 'da build php_ini': no
Cron for notifications and (or) updates: yes
Cron frequency: daily
Run "clean_old_webapps" every time: yes
Show texts in bold: yes
SquirrelMail: no
Zend Guard Loader: no
ionCube loader: no
Suhosin: no
and PHP extensions
Imunify360
It is a commercial software, Directadmin is not shipped with it.
DA installs redis-8.2.3 on AlmaLinux 10 from a source.
Firewalld
csf: v15.05 (DirectAdmin) is running fine too
PHP extensions
What is wrong with them?
Bash:
[root@dev10 custombuild]# grep ^php_.*=yes options.conf
php_imagick=yes
php_redis=yes
PHP options can be changed as usually:
Bash:
[root@dev10 ~]# php -i | grep -i memory_limit
memory_limit => 128M => 128M
[root@dev10 ~]#
[root@dev10 ~]# echo 'memory_limit=512M' >> /usr/local/php84/lib/php.conf.d/90-custom.ini
[root@dev10 ~]#
memory_limit => 512M => 512M
[root@dev10 ~]#
[root@dev10 ~]#
[root@dev10 ~]# php -v
PHP 8.4.14 (cli) (built: Oct 29 2025 05:08:52) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.4.14, Copyright (c) Zend Technologies
[root@dev10 ~]#
[root@dev10 ~]# uname -r
[root@dev10 ~]#
I've got a set of additional measures for an each new server, and I do follow certain steps to make a server ready. Probably If I re-install OS and DirectAdmin it will miss some requirements, but it is no way critical, I believe.
What do I do wrong?
You should first enabled it in options.conf:
Bash:
da build set redis yes
da build redis
da build set php_redis yes
da build php_redis
After performing a clean installation and carefully configuring everything, I now have a server as stable as yours. So my previous comment is no longer valid :) I can’t say everything is perfect on AlmaLinux 10, but I made good progress by solving the issues that came up. Your feedback is important to me. Thank you for taking the time to help.
On a fresh Alma 10 box, DA won't install properly, because CSF
[root@main directadmin]# more custombuild.1765229519.125551.YWxsAA.log
Installing sysbk...
Installed:
epel-release-10-6.el10.noarch
selinux-policy-extra-42.1.7-1.el10.noarch
selinux-policy-targeted-extra-42.1.7-1.el10.noarch
Installed:
bind-32:9.18.33-10.el10_1.2.x86_64
bind-dnssec-utils-32:9.18.33-10.el10_1.2.x86_64
Added 'allow-transfer { none; };' to /etc/named.conf
Created symlink '/etc/systemd/system/multi-user.target.wants/named.service' -> '/usr/lib/systemd/system/named.service'.
Installed:
ipset-7.22-8.el10.x86_64
ipset-libs-7.22-8.el10.x86_64
iptables-nft-1.8.11-11.el10.x86_64
kernel-modules-extra-6.12.0-124.13.1.el10_1.x86_64
kernel-modules-extra-matched-6.12.0-124.13.1.el10_1.x86_64
libnftnl-1.2.8-4.el10_1.x86_64
perl-Clone-0.46-10.el10.x86_64
perl-Data-Dump-1.25-13.el10.noarch
perl-Digest-HMAC-1.04-12.el10.noarch
perl-File-Listing-6.16-5.el10.noarch
perl-HTML-Parser-3.82-3.el10.x86_64
perl-HTML-Tagset-3.20-59.el10.noarch
perl-HTTP-Cookies-6.11-5.el10.noarch
perl-HTTP-Date-6.06-6.el10.noarch
perl-HTTP-Message-6.45-5.el10.noarch
perl-HTTP-Negotiate-6.01-40.el10.noarch
perl-IO-HTML-1.004-14.el10.noarch
perl-LWP-MediaTypes-6.04-19.el10.noarch
perl-NTLM-1.09-41.el10.noarch
perl-Net-HTTP-6.23-6.el10.noarch
perl-TimeDate-1:2.33-16.el10.noarch
perl-Try-Tiny-0.31-12.el10.noarch
perl-WWW-RobotRules-6.02-41.el10.noarch
perl-libwww-perl-6.76-3.el10.noarch
Installing CSF...
download_cached: downloading 'https://files.directadmin.com/services/csf-15.05.tar.gz' to '/usr/local/directadmin/custombuild/cache/csf-15.05.tar.gz'
preliminary test failed, CSF is missing some modules
command_csf: failed to compile '/usr/local/directadmin/custombuild/cache/csf-15.05.tar.gz' inside '/usr/local/directadmin/custombuild/tmp/tmp.SPgbIyp6Br.csf-15.05.tar.gz'
2025/12/08 21:32:25 info executing task task=action=notify&message=CustomBuild+installation+has+failed%2C+please+check+the+following+file+for+more+information%3A%0A%2Fvar%2Flog%2Fdirectadmin%2Fcustombuild.1765229519.125551.YWxsAA.log&subject=Cu
stomBuild+installation+has+failed&value=admin
2025/12/08 21:32:25 info finished task duration=19.625832ms task=action=notify&message=CustomBuild+installation+has+failed%2C+please+check+the+following+file+for+more+information%3A%0A%2Fvar%2Flog%2Fdirectadmin%2Fcustombuild.1765229519.125551.
YWxsAA.log&subject=CustomBuild+installation+has+failed&value=admin
disabling csf in /usr/local/directadmin/custombuild/options.conf and then updating manually seems to have fixed this
Installer should not be trying to install CSF since it obviously won't work
Right now the biggest problem with RHEL 10 or AlmaLinux 10 is that rspamd does not provide packages for this version (yet). This means DA on RHEL10 systems can only use spamassassin. We expect rspamd to start providing RPMs for newer systems soon.
Hello team
Rspamd already provided RPMs for RHEL10. Will it works with Almalinux 10 ?
@gurek, The legacy DirectAdmin will not work with systems based on RHEL 10 - CentOS 10, Alma Linux 10, RockyLinux 10.
Hi fln,
Following up on the recent discussions regarding OS support and system requirements for version 10 distributions (such as AlmaLinux 10 and Rocky Linux 10), I would appreciate a bit of official clarification regarding the license eligibility.
As staff member @fln mentioned earlier, legacy/lifetime DirectAdmin licenses will not be supported on RHEL 10-based systems. Could the team or moderators elaborate a bit more on the technical or policy background behind this limitation? Specifically:
Is this restriction driven by architectural/dependency changes in RHEL 10 (such as system libraries, PHP/compiler changes, or underlying package toolchains) that legacy builds cannot accommodate, or is it strictly tied to the licensing model tier?
For infrastructure administrators currently managing a large fleet under legacy licenses, what is the recommended long-term migration roadmap or policy path as AlmaLinux 8/9 eventually approach their lifecycles?
Thanks,
That.
Modern licenses will support RHEL 10 based systems and newer Debian and derative systems.
I would say convert the legacy licenses to modern licenses then you can upgrade all. Price when converting/upgrading to modern licenses is half of normal price so 15/month.
