DirectAdmin 1.714
@infracom2005. The * symbol near the version means you have the latest version but it does not have all the patches that we prepared for this version. In other words the version with * is problematic and needs to be updated.
Yes if you would rebuild it a new version with all the patches would be compiled and you would be up to date.
Thank you @fln and all DA team and everyone else who contributed to patch. You guys are the best! Love you guys <3
Thanks @pat0, the stable release channel should be ok now. It needed some changes to be backported from current release channel. The patches and new versions are also pushed to the EOL rhel7 and debian10 release channels.
I've yet to take the time to update my debian from EOL due to high cron usage on one of my sites.🙈
At least you have the heart to include these fixes in the EOL OS.
@pstoilov, the reason we are going away from custom suspension reasons file is:
  • make sure suspension reasons are translatable (to other languages than English). The additional translations in custom translations file was untranslatable.
  • To avoid placing user controlled data inside the apache configuration file (the fully translated suspension reason text).
Our goal is to have a pre-defined list suspension reasons. If the list is too short - just let us know we will add more suspension reasons.
If you would like to show arbitrary message (the suspension details) in the suspension page, this would be a feature request.
Thank you, but I am a bit confused. You will still support a list of pre-defined suspension reasons. So I can see them in the suspend dialog - Abuse, Billing, Inactivity..... The file in templates dir /usr/local/directadmin/data/templates/suspension_reason.txt is missing. Also from announce :
It is no longer possible to set a reason when suspending a domain. The following lists what was removed.
Enhanced skin:
    Domain suspension reason is no longer shown anywhere in the skin
API:
    /CMD_DOMAIN reason parameter
CLI:
    da suspend-domain --reason option
Templates:
    SUSPENDED_REASON httpd.conf template token
What that means - Suspend reason is no longer supported via API? Because either, I can change my workflow and use default reasons to display different suspend pages.
From the quoted changelog, the `reason` parameter is intentionally gone from `/CMD_DOMAIN`, as is the CLI `--reason` option and the `SUSPENDED_REASON` token. So the API no longer supports setting a custom per-domain suspension reason; pre-defined/translatable reasons are the replacement. If your workflow used the reason text to select different suspension pages, that logic will need to move outside DirectAdmin or be mapped to the available pre-defined categories. The missing `suspension_reason.txt` is likely part of the same removal, not a separate bug.
@pstoilov, sorry for the confusion. I was writing about the changes in user suspension (not domain suspension). The domain suspension messages were removed, because they were never supported in Evolution (only in Enhanced). And we never get a request for Evolution to support it. This hinted that having reasons for domain suspension is not a needed feature.
For the MySQL 9.7 now supported:
Should this be treated as a experimental version or as a mature version like 8.4 is? (From DA perspective as DA integrates really deeply into the database.)
And I totally get that the new way MySQL 9.7 handles passwords is a pain for older systems/hosts but can I expects a smooth transition from 8.4 (and where no older versions where ever used) to 9.7 or will it still become a pain because of the password changes in 9.7?
Edit: nevermind, when changing the version to 9.7 custombuilds refuses to update mysql to 9.7. (So definitely should be treated as experimental.)
