Errors please help
Phantium
Netherlands
Please help, I'm getting these DirectAdmin errors since the 27th of march.
2007:04:01-04:21:02: Unable to delete bytes log: ./data/users/admin/DAdminUsage.bytes : <b>Write access to the directory containing ./data/users/admin/DAdminUsage.bytes is not allowed for the process's effective uid, or one of the directories in pathname did not allow search (execute) permission.</b><br>
2007:03:27-00:10:03: Unable to delete bytes log: /var/log/httpd/domains/domain.ext.bytes : Error truncating /var/log/httpd/domains/domain.ext.bytes : Permission denied<br>
And then these Dovecot errors which I have been getting for a while as well:
Apr 3 19:04:28 server dovecot[12020]: auth(default): passwd-file(username,217.*.*.*): no passwd file: /etc/virtual//passwd
I am having similar issues with the second part about /etc/virtual//passwd
It only happens for user accounts and not virtual email accounts.
Freebsd 6.2
It should be /etc/virtual/domain/passwd, that's the problem. I guess you're using dovecot, you should want to take a look at /etc/dovecot.conf. More accurate at
args = /etc/virtual/%d/passwd
Thanks smtalk, this means that by default when you upgrade to dovecot with DirectAdmin the config file is inaccurate and points to the wrong directory!
Hey what the heck... my config file already has
but it doesn't recognize the %d string! what can I do to fix this?
Try this:
rm -rf dovecot-1.0.rc30.tar.gz
wget http://dovecot.org/releases/dovecot-1.0.rc30.tar.gz
tar xzf dovecot-1.0.rc30.tar.gz
cd dovecot-1.0.rc30
./configure --prefix=/usr --sysconfdir=/etc --localstatedir=/var --without-gssapi --with-passwd-file
make
make install
After all restart the dovecot service.
May I check your server? If yes - contact me via instant messenger.
jlasman, no he hasn't ;) I've just looked through it, he has tried to use just user instead of user@domain, that's why %d wasn't working.
I believe it was a change made about a month ago to the dovecot.conf. I changed it back today. A user suggested we put the virtual user password checks first (for system accounts) to speed up access, as the main account user doesn't login very much. The problem with that was that the system user doesn't have a domain, so a non-existant file is checked. I've returned it to it's previous state.
To get the new dovecot.conf type:
wget -O /etc/dovecot.conf http://files.directadmin.com/services/customapache/dovecot.conf
Hmmm.
I still have this problem. I tried everything above but none of it worked for me :(
Could someone please help me?
