Admin level domain and LetsEncrypt
ingvar3000
I'm having trouble getting an SSL cert on the root domain of the my server hostname.
I've been getting this error message:
Account admin with domain rootdomain.net has an empty caroot cert
The file:
/usr/local/directadmin/data/users/admin/domains/rootdomain.net.cacert
belonging to account admin, domain rootdomain.net, is either empty or missing,
but it's set to be used in that domain's config.
This is an incorrect state, so please re-add or unset file, and notify DirectAdmin support if it re-occurs.
I recently renamed the server hostname and ran the Letsencrypt script, so now https://host.rootdomain.net has the cert lock. But https:rootdomain.net does not. rootdomain.net is attached to the "admin" account. I would like to have an actual website at rootdomain.net. What am I missing here?
Richard G
Maastricht
What exactly did you do?
Like this with the request_single? And did you do every step, including the directadmin.conf change and restarting directadmin?
https://help.directadmin.com/item.php?id=629
Did you also enable everything to be able to activate a certificate for rootdomain.net and used the create function from user level in admin afterwards?
https://help.directadmin.com/item.php?id=648
Do you use the latest DA version or at least 1592 or newer? As this looks like an issue which was fixed before:
https://www.directadmin.com/features.php?id=2552
ingvar3000
Richard, thanks for the feedback. I think the problem was that the Centos hostname was something completely different. I changed that to match the DirectAdmin settings, ran through the scripts you recommended again, and the empty caroot cert problem resolved.
Richard G
Maastricht
You're welcome.
Indeed the hostname should be the same as in DA. So it's good you found the cause. Thank you for reporting back.
