backup problem
uvhost
UK
While trying to backup my server to external server, DA is not able to backup databases and i get errors like this:
User admin has been backed up. <19:38:47>
Error while backing up database ehost_bles472
Error while backing up database ehost_bles472: The sql file is 0 bytes in size: /home/tmp/admin.15006/ehost/backup/ehost_bles472.sql
mysqldump error output: /usr/bin/mysqldump: unknown variable 'local-infile=0'
any idea how can i solve this issue?
ditto
You need to edit /etc/my.cnf and move local-infile=0 AFTER [mysqld] - if your my.cnf file does not have the line [mysqld], then you should create [mysqld] right above local-infile=0
It other words, local-infile=0 needs to be below [mysqld] in my.cnf
