gate2vn said:
Sorry, I am new in DA. I have some questions
- do I have to create "user_backups" folder before running this tool?
- do I need to create end-user account before restoring?
- how can I restore backup file?
I have created reseller account, move converted file to user_backups folder, but cannot see it in DA.
Pls help. thanks,
i did not write the program but do use it.
i did not have to create a "user_backups" folder. It already existed in my admin (reseller) domain folder. (/home/admin/user_backups)
you do not have to create the end user account, but you do need to have a package type that the restore is going to go to.
in my case, i had new settings for the users account. for example, instead of only giving 2 ftp accounts, I give 4 and instead of unlimited mySQL, i change it to 25.
First thing I did to ensure the backrestore worked was to create a package in my restore that was bigger than any user had. When the backup restore was done, I then go back to the reseller user list and change the user package to the assigned package which changes all the setting to what i want.
there are a lot of ways to skin a cat...this was my method of choice. I did find this out too....i had a plan called "Gold" and when I did the conversion, the plan loaded for the user was "gold". Not knowing if case sensativity was an issue, I made the big plan and had that in the configuration file. Changed the plan on the user once restore was done.
The FTP limit is the user package limit you have set. change the setting to unlimited and it should import fine.
hope this helps...
Once the file is converted, it is put into the "export folder". I don't recall if there is any automation there, but I simply move the file from export to user_backups. Then, in the reseller backup, I am able to restore it. If you are not seeing the tar file in the reseller backup, then the file is not in the user_backups folder.
restore is done from reseller backup area. pretty straight forward.
