cpan
Terminal does not support AddHistory.
cpan shell -- CPAN exploration and modules installation (v1.9800)
Enter 'h' for help.
cpan[1]> install Bundle::CPAN
Reading '/root/.cpan/sources/authors/01mailrc.txt.gz'
............................................................................DONE
Reading '/root/.cpan/sources/modules/0****kages.details.txt.gz'
Database was generated on Tue, 15 Mar 2016 12:29:02 GMT
HTTP::Date not available
New CPAN.pm version (v2.10) available.
[Currently running version is v1.9800]
You might want to try
install CPAN
reload cpan
to both upgrade CPAN.pm and run the new version without leaving
the current session.
Reading '/root/.cpan/sources/modules/03modlist.data.gz'
Catching error: "Can't locate object method \"data\" via package \"CPAN::Modulelist\" (perhaps you forgot to load \"CPAN::Modulelist\"?) at (eval 19) line 1.\cJ at /usr/share/perl5/CPAN/Index.pm line 524.\cJ\cICPAN::Index::rd_modlist('CPAN::Index', '/root/.cpan/sources/modules/03modlist.data.gz') called at /usr/share/perl5/CPAN/Index.pm line 85\cJ\cICPAN::Index::reload('CPAN::Index') called at /usr/share/perl5/CPAN.pm line 976\cJ\cICPAN::exists('CPAN=HASH(0x2dfca70)', 'CPAN::Bundle', 'Bundle::CPAN') called at /usr/share/perl5/CPAN/Shell.pm line 1356\cJ\cICPAN::Shell::expand_by_method('CPAN::Shell', 'CPAN::Bundle', 'ARRAY(0x2f04868)', 'Bundle::CPAN') called at /usr/share/perl5/CPAN/Shell.pm line 1273\cJ\cICPAN::Shell::expand('CPAN::Shell', 'Bundle', 'Bundle::CPAN') called at /usr/share/perl5/CPAN/Shell.pm line 1254\cJ\cICPAN::Shell::expandany('CPAN::Shell', 'Bundle::CPAN') called at /usr/share/perl5/CPAN/Shell.pm line 1681\cJ\cICPAN::Shell::rematein('CPAN::Shell', 'install', 'Bundle::CPAN') called at /usr/share/perl5/CPAN/Shell.pm line 1977\cJ\cICPAN::Shell::__ANON__('CPAN::Shell', 'Bundle::CPAN') called at /usr/share/perl5/CPAN.pm line 376\cJ\cIeval {...} called at /usr/share/perl5/CPAN.pm line 373\cJ\cICPAN::shell() called at /usr/share/perl5/App/Cpan.pm line 295\cJ\cIApp::Cpan::_process_options('App::Cpan') called at /usr/share/perl5/App/Cpan.pm line 364\cJ\cIApp::Cpan::run('App::Cpan') called at /usr/bin/cpan line 11\cJ" at /usr/share/perl5/CPAN.pm line 392.
Warning: Your /root/.cpan/sources/modules/0****kages.details.txt.gz does not contain a Line-Count header.
Please check the validity of the index file by comparing it to more
than one CPAN mirror. I'll continue but problems seem likely to
happen.
Warning: Your /root/.cpan/sources/modules/0****kages.details.txt.gz does not contain a Last-Updated header.
happen.
2E~�g���ViJ�D�\\�\cT��\cT,��S���Q���zI�a4m�U)\cG�\cT)om�2�q�\cQ\c]5�{\cG.I\cY��\cV|L�FQ|��ci�/\cX%)�\cCMy"]\cK�\\�\cT.s�S`��`\\�
Could not split line["3�G"]
Could not split line["?�\c?K�\cW��Y�\cN����\cT�)�r��L��'^�|1i�{=��o%��\cTj�\cH�"]
Could not split line["��K�%\cH�B}P\cG��\c?�\c]�\cF�6�5��m��W\cX��<\cQs���d������9b��\cM�D'�0�<\cC\"`�\cA\cGa+?J��`\c?(\cR�\\}\cY\\\cOn��\\�P�'�\c@�T!"]
Giving up parsing your /root/.cpan/sources/modules/0****kages.details.txt.gz, too many errorsTerminal does not support GetHistory.
Lockfile removed.
[root@ns2 ~]# /usr/local/directslave/bin/directslave --check
defined(@array) is deprecated at /usr/local/directslave/bin/../lib//DSGI.pm line 528.
(Maybe you should just omit the defined()?)
Base class package "Net::Server::HTTP" is empty.
(Perhaps you need to 'use' the module which defines that package first,
or make that module available in @INC (@INC contains: /usr/local/directslave/bin/../lib/ /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .).
at /usr/local/directslave/bin/directslave line 11.
BEGIN failed--compilation aborted at /usr/local/directslave/bin/directslave line 11.
