roman_m
It's not creating the zone file.
They shouldn't, because 'master' mode is deprecated in since DS 2.х. It works in 'slave' by default. Check new records in file 'named_conf', they created as
zone "domain_name" { type slave; file "/named_db_path/domain_name.db"; masters { your_primary_IP; }; max-retry-time 1200; min-retry-time 1200; };
right?
If so, you must setup AXFR right on your primary, or downgrade to 1.3 to continue to use 'master' mode.
