quackweb
He doesn't work for DA. The only username DirectAdmin will post under is DirectAdmin Support.
jlasman said:Let's take a try at resolving the confusion.
No user named ubersmith has posted anything to this thread.
ubersmith.com is the website for the control panel user empoweri recommended.
The website indicates only that it is integrated with CPanel.
I have no idea if it is integrated with DirectAdmin or not; you'd have to ask the publishers.
matthewventura said:Does ubersmuth work with DA?
If they don't reply then its an advertisement most likely. It's just interesting to notice it. I'm not saying you should remove it, just making a note of it.
quackweb said:I agree, we use MB and it's a pain in the butt sometimes and breaks frequently for some very odd reason. It's too expensive to buy and once you buy it, you have to renew your "support license" to get upgrades. Plus it has NO support for dedicated servers/colocation accounts.
Hopefully we will be making our own billing system soon as most on the market just don't cater to our needs. If you do decide to go forth and build the biling system for mass production, let us know!
GXX said:
datawebcorp said:GXX,
After seeing your post, I took a good look at AWBS. It seems nice. Inexpensive too.
Do you use it? What do you like/dis-like? If you're familiar w/ModernBill, how would you compare the two?
TIA.
jechilt said:Greetings,
I have been using AWBS for a few years now. Initially, I started with WhoisCart, tested MB and a slew of others. MB is quite a big application and can do quite a bit. We were not sold onthe user interface and it seemed it took a long time to navigate through the tool due to slow load times. For us, it was just too much application for what we needed.
AWBS have grown into quite a nice tool. Although there are a lot of features, it is not bogged down and runs at a decent pace. No complaints from me. You can get the product by buying the license outright or leasing. We started with leasing.
For us, there were 2 primary components that sold us. First, our users claim the user control panel is easy to use and second, it comes with several web skins for the front end. You could look at this as a turn-key solution. We have built our own skins and menu system without too much trouble.
If there is any components that I am not crazy about it would be the long delay in getting DA API interface for disk use computations. This has never been an issue for us so we don't press the issue that much.
Fpr domain services, AWBS has good integration with Enom. The domain services are a bit lacking for directI but we just provided them the new API's (updated 10Jan) and they said they will start looking into it.
The last item we would like to get integrated is free domain renewal for anual account renewals. Currently, it allows free domain at first registration but not permanently. I don't know if or when a permanent free domain name will come available. There are adequate billing options, to include add-ons etc. We are happy with the ease of setting up the account options. Coupons are great...no problems there.
AWBS continues to improve their product and have recently been including more options. For example, if you want to use the built in help desk you can or you can enable Kayako.
The forum is quite active and we have never had a support problem. When we have used support, they have been to the rescue. I guess it is another reason we still use the product.
Hope this info is helpful in making your decision...
