ftp problems
gunit
Puerto Rico
hi
i try to enter to my ftp and give me an error that i dont have perrmision to enter. But i put my username and password and i enter but i cant see nothing.
Do you own your own DirectAdmin server?
If so you should probably check to see if your firewall isn't allowing passive connections through.
If you're a hosting customer then you should probably contact your hosting company's support group, because they're the only ones who can help you.
hi
hi
yes i own the server but the firewall not. So i goin to talk with the data center support. Thanks.
