IPv6 problems in DA 1.59
Servertramp
Hi All,
I'm running into a problem with setting up the IPv6 adress in the new interface of DA version 1.59.
I started with the usual setup instructions following: https://help.directadmin.com/item.php?id=353
After that, i tried to add the IPv6 by Admin Level' -> 'IP Management'.
When i enter my ipv6 adress, it seems the adress is to short. So i can't press the "add ip" button.
Is there someone who has runned into the same problem?
Thanx in advance!
