need some help please
DAclub
hello everyone.
am new to DA i was using WHM b4 but i decided to switch to DA. however i have some questins please that i need some help with
1- how can i make more than 1 reseller use his domain name as the namesever while the ips of the nameservers are shared ?
2- just like the first question but this one is for end users using their private domains as nameservers but those nameserver are shared IPs between resellers
3- can someone provide a link for SSH commands ?
i apreciate your help
thank you
thank you Chris for your reply.
i didnt find the attached example mentioned on the post you mentioned, can you please shed some light on it ?
thank you again
The nameserver is a howto guide and the instructions are in the post, the o'reilly link is an alphabetical directory of linux commands :)
I dont there are any attatchments..
Chris
ok sorry, not got the screen shot handy :D
for this example your CURRENT nameservers are (just replace these with your actual domains and IP addresses):
ns1.serverdomain.com | 111.111.111.111
ns2.serverdomain.com | 222.222.222.222
and you want your new nameservers to be:
ns1.domain.com | 111.111.111.111
ns2.domain.com | 222.222.222.222
1 go into admin panel
2 DNS administration
3 Select the domain "domain.com"
4 at the bottom of the page you willl see a section "Add Domain Records"
5 on the top line, in the first field (before the "A") type "ns1.domain.com" or the name of your nameserver nameserver1.domain.com
for example.
6 in the field to the right of the A type "111.111.111.111"
7 Click "add" to add the new record!
8 - repeat steps 5, 6 and 7 for ns2 using ns2.domain.com and 222.222.222.222
Hope this helps :)
Chris
thank you very much chris. does this apply to when i want more than reseller to use a virtual nameservers IPs while using their own domain name as nameservers ?
thanks a million :)
when the reseller requests personal nameservers on resellerdomain.com...
replace all instances of:
ns1.domain.com
ns2.domain.com
to
ns1.resellerdomain.com
ns2.resellerdomain.com
and go through the process again :)
Chris
thank you so much chris
i updated some nameservers waiting for propagation.
i will let you know who things went .
Thank you again :)
Chris,
Just wanted to let you know that everything worked the way you described .
thank you
