Problem with eaccelerator - Error 500
jim.thornton
I just installed eAccelerator via update.script. The installation seemed to go fine, however, once I add the lines to my php.ini file it is giving me an error 500.
[PHP]
zend_extension=/usr/local/lib/ioncube/ioncube_loader_lin_5.2.so
zend_extension=/usr/local/lib/Zend/ZendOptimizer.so
[Zend Optimizer]
zend_optimizer.optimization_level=15
[eAccelerator]
;zend_extension="/usr/local/lib/php/extensions/no-debug-non-zts-20060613/eaccelerator.so"
;eaccelerator.shm_size="32"
;eaccelerator.cache_dir="/tmp/eaccelerator"
;eaccelerator.enable="1"
;eaccelerator.optimizer="1"
;eaccelerator.check_mtime="1"
;eaccelerator.debug="0"
;eaccelerator.filter=""
;eaccelerator.shm_max="0"
;eaccelerator.shm_ttl="0"
;eaccelerator.shm_prune_period="0"
;eaccelerator.shm_only="0"
;eaccelerator.compress="1"
;eaccelerator.compress_level="9"
That is the first 20 lines (or so) of my php.ini file. I've inserted the eaccelerator line after the zend optimizer... Is that right?
anyone know why I'm getting this error?
I just made the changes to my PHP4 and it gave me a 500 error again. This time it is in front.
Is there a compatibility issue with PHP4?
here are the first lines to my PHP4 php.ini file:
[eAccelerator]
[PHP]
zend_extension=/usr/local/lib/ioncube/ioncube_loader_lin_4.4.so
zend_extension=/usr/local/lib/Zend/ZendOptimizer_4_4.so
[Zend Optimizer]
zincoxide, if you want - I can take a look at your server for free.
