[Release] Rspamd web interface plugin for DirectAdmin - v0.1
I'm not sure what Alex's Rspamd plugin did. DA has native rspamd interface integrated. If plugin had something else than this or if you need plugin for some other reasons - you can run both
A rSpamd plugin from Poralix was released a while before DirectAdmin started to offer the same web-interface to manage rSpamd. Technically they do the same.
Have same problem , rspamd return zero scan , was try few time rebuild rspamd also rspamd_conf but result still same
Ps: just in scan/learn function its work for manual scanning
Its not about php 8 issue i think, because i try in php 7.4 also zero scan
A web interface for rSpamd only prints stats to a browser from a daemon. You might check your installation and make sure rSpamd/SpamAssassin is enabled for your specific domain. You might need to take an extra step to switch ON it for every hosted domain.
Yes @zEitEr i think this issue come with new installation of directadmin after 1.643 because we used rspamd in other server before and no issue like this.
For installation and procedure i was check and make sure everything has no problem .
please help me here is rspamd logs error list and webui I setup everything is fine on fresh directadmin server
2024-05-08 06:47:33 #205025(controller) rspamd_http_connection_new_client: cannot connect make http connection to [2606:4700:20::681a:bf7]:443: Cannot assign requested address
2024-05-08 06:47:33 #205025(controller) <n4etoq>; map; rspamd_map_dns_callback: cannot connect to [2606:4700:20::681a:bf7]:443 to get data for https://maps.mailbaby.net/ch/digest.map: Cannot assign requested address, retry with 104.26.10.247:443 (2 of 6)
2024-05-08 06:47:33 #205025(controller) <n4etoq>; map; http_map_finish: need to reread map from https://maps.mailbaby.net/ch/digest.map
2024-05-08 06:47:33 #205025(controller) <n4etoq>; map; http_map_finish: stored map data in a shared memory cache: /rhm.58efa58974fb4000a9b5
2024-05-08 06:47:33 #205025(controller) <n4etoq>; map; http_map_finish: https://maps.mailbaby.net/ch/digest.map(104.26.11.247:443): read map data 30918 bytes, next check at Wed, 08 May 2024 05:52:33 GMT
2024-05-08 06:47:33 #205025(controller) <n4etoq>; map; rspamd_map_save_http_cached_file: saved data from https://maps.mailbaby.net/ch/digest.map in /var/lib/rspamd/42a3085d98166a4bdc26c0c607113920629fa279.map, 30958 bytes
2024-05-08 06:47:33 #205025(controller) <n4etoq>; map; rspamd_kv_list_fin: read hash of 936 elements from https://maps.mailbaby.net/ch/digest.map
2024-05-08 06:47:35 #205028(normal) <n4etoq>; map; rspamd_map_common_http_callback: need to reread cached map triggered by https://maps.mailbaby.net/ch/digest.map (1715146569 our modify time, 1715147169 cached modify time)
2024-05-08 06:47:35 #205028(normal) <n4etoq>; map; rspamd_map_read_cached: https://maps.mailbaby.net/ch/digest.map: read map data cached 30918 bytes
2024-05-08 06:47:35 #205028(normal) <n4etoq>; map; rspamd_kv_list_fin: read hash of 936 elements from https://maps.mailbaby.net/ch/digest.map
2024-05-08 06:47:36 #205035(normal) <n4etoq>; map; rspamd_map_common_http_callback: need to reread cached map triggered by https://maps.mailbaby.net/ch/digest.map (1715146569 our modify time, 1715147169 cached modify time)
2024-05-08 06:47:36 #205035(normal) <n4etoq>; map; rspamd_map_read_cached: https://maps.mailbaby.net/ch/digest.map: read map data cached 30918 bytes
2024-05-08 06:47:36 #205035(normal) <n4etoq>; map; rspamd_kv_list_fin: read hash of 936 elements from https://maps.mailbaby.net/ch/digest.map
2024-05-08 06:47:42 #205025(controller) <s5prdy>; map; rspamd_map_cache_cb: cached data is now expired (gen mismatch 1 != 2) for https://maps.mailbaby.net/ch/attachment.map; shm name=/rhm.32eb85e7a15502e4bf20; refcount=1
2024-05-08 06:47:42 #205025(controller) <n4etoq>; map; rspamd_map_cache_cb: cached data is now expired (gen mismatch 1 != 2) for https://maps.mailbaby.net/ch/digest.map; shm name=/rhm.4e3395837b795c49fdc8; refcount=1
2024-05-08 06:47:42 #205025(controller) <fiz5ni>; map; rspamd_map_cache_cb: cached data is now expired (gen mismatch 1 != 2) for https://maps.mailbaby.net/dqs/dqs_subject.map; shm name=/rhm.0a03f322fc0d9cada339; refcount=1
2024-05-08 06:47:42 #205025(controller) <mwrqjt>; map; rspamd_map_cache_cb: cached data is now expired (gen mismatch 1 != 2) for https://maps.mailbaby.net/ch/ch_shorturl.map; shm name=/rhm.88e717d1be91219474d7; refcount=1
2024-05-08 06:47:46 #205032(normal) <n4etoq>; map; rspamd_map_common_http_callback: need to reread cached map triggered by https://maps.mailbaby.net/ch/digest.map (1715146569 our modify time, 1715147169 cached modify time)
2024-05-08 06:47:46 #205032(normal) <n4etoq>; map; rspamd_map_read_cached: https://maps.mailbaby.net/ch/digest.map: read map data cached 30918 bytes
2024-05-08 06:47:46 #205032(normal) <n4etoq>; map; rspamd_kv_list_fin: read hash of 936 elements from https://maps.mailbaby.net/ch/digest.map
2024-05-08 06:47:56 #205030(normal) <n4etoq>; map; rspamd_map_common_http_callback: need to reread cached map triggered by https://maps.mailbaby.net/ch/digest.map (1715146569 our modify time, 1715147169 cached modify time)
2024-05-08 06:47:56 #205030(normal) <n4etoq>; map; rspamd_map_read_cached: https://maps.mailbaby.net/ch/digest.map: read map data cached 30918 bytes
2024-05-08 06:47:56 #205030(normal) <n4etoq>; map; rspamd_kv_list_fin: read hash of 936 elements from https://maps.mailbaby.net/ch/digest.map
2024-05-08 06:48:39 #205025(controller) <274f8d>; csession; rspamd_controller_check_password: allow unauthorized connection from a unix socket
2024-05-08 06:48:39 #205025(controller) <bd348e>; csession; rspamd_controller_check_password: allow unauthorized connection from a unix socket
2024-05-08 06:48:42 #205025(controller) <6a0763>; csession; rspamd_controller_check_password: allow unauthorized connection from a unix socket
2024-05-08 06:48:42 #205025(controller) <377f26>; csession; rspamd_controller_check_password: allow unauthorized connection from a unix socket
2024-05-08 06:48:42 #205025(controller) rspamd_inet_address_connect: connect [2606:4700:20::ac43:495b]:443 failed: 99, 'Cannot assign requested address'
2024-05-08 06:48:42 #205025(controller) rspamd_http_connection_new_client: cannot connect make http connection to [2606:4700:20::ac43:495b]:443: Cannot assign requested address
2024-05-08 06:48:42 #205025(controller) <xh8c4k>; map; rspamd_map_dns_callback: cannot connect to [2606:4700:20::ac43:495b]:443 to get data for https://maps.mailbaby.net/mb_high_spam_url.map: Cannot assign requested address, retry with 104.26.11.247:443 (2 of 6)
2024-05-08 06:48:42 #205025(controller) <xh8c4k>; map; http_map_finish: data is not modified for server maps.mailbaby.net, next check at Wed, 08 May 2024 05:53:42 GMT (timer based)
2024-05-08 06:48:52 #205025(controller) <6e4c48>; csession; rspamd_controller_check_password: allow unauthorized connection from a unix socket
2024-05-08 06:48:52 #205025(controller) <829831>; csession; rspamd_controller_check_password: allow unauthorized connection from a unix socket
