SMTP problems
Marque DeWinter
all emails sent out are being bounced saying the host could not be located (address won't resolve)
Error messages are as follows:
2004-11-24 07:44:03 1CWZSs-0008It-Qw == user@doman.com routing defer (-51): retry time not reached
2004-11-24 07:43:43 1CVSP7-0001Xb-0y == user@domain.com <user@domain.com> R=lookuphost defer (-1): host lookup did not complete
I'm thinking its the router, not the machine or Exim. Could someone confirm or deny that?
Marque DeWinter
My hostname is completely different
my hostname (and even ther server domain name) is completely different.
the hostname is
sever.domain.net
which isn't even listed on the DNS page (or just even the domain.net)
nobaloney
California
You didn't give us any real information to go on, so I can't do any testing.
But I will say that in order to send email your hostname must resolve in DNS.
If it doesn't most mailservers (including mine) won't accept email from you.
Marque DeWinter
What information is needed
Well what information will help? I'm not great with DA and the effects it has on the various programs (exim, apache, etc.). I could just change the config files directly but I don't how DA will react.
Again sample error messages from the logs are as follows
AND
as per the previous post the servers hostname is not the same as the domain. The servername ends in .NET and the domain ends in .COM
PLUS the kicker to all of this is that it worked fine until the machine was restarted.
Thanx, MD
fusionictnl
Netherlands
We don't mean as the domain that's sending the email to. We mean you can't have the hostname as domainname even when you're not mailing to it ;)
Let's say you're hostname is server1.domain.ext
and you create a domainname in the panel "server1.domain.ext".
Then all you're mails to [username]@something.ext isn't working.
But if it isn't check the thread there's a way to trace the email routers in exim and find the problem ;)
nobaloney
California
Re: What information is needed
Okay, let's presume for a moment your server is really named sever.domain.net
A simple nslookup on server.domain.net shows that you don't have a zone entry in DNS for it:
[jeff@of1 jeff]$ nslookup server.domain.net
Server: 192.168.2.1
Address: 192.168.2.1#53
** server can't find server.domain.net: NXDOMAIN
[jeff@of1 jeff]$
Fix your DNS, and your email will work.
