Which law would that be? Do you have a reference to it?blacknight said:Under European law we are obliged to retain logs, though for how long is still to be decided.
There's an EU directive on data retention that is currently being discussed by EURISPA and the national governments.mike_p said:Which law would that be? Do you have a reference to it?
Exactly.rldev said:
There are many solutions out there for sure. SA should be a plugin, I don't see why this should be such a big deal.
SpamAssassin is installed but not configured. It is not yet version 3.0.albatroz said:So what is the current status of SpamAssassin, does it comes installed by default? if so, which version? 3.0?
BigWil said:No really there isn't. Those other threads are so messed up, cluttered and out of date that I just spent an hour trying to fix my install.
If you feel so strongly about it why don't you post a new thread with what you would consider to be the most current information on the topic?BigWil said:
An up-to-date thread MUST be created and it should also have instructions of upgrading exim and spamassasin the the current DA versions.
BigWil
DirectAdmin Support said:Hello,
I can look into a "condition" for turning it off. It would be a simple addition to the exim.conf where if the user_prefs file doesn't exist, spamassassin is not run for that user. To turn it off, just delete the user_prefs (ill provide a button for the user).
So, and where is that button?DirectAdmin Support said:I can look into a "condition" for turning it off. It would be a simple addition to the exim.conf where if the user_prefs file doesn't exist, spamassassin is not run for that user. To turn it off, just delete the user_prefs (ill provide a button for the user).
