starting ./directadmin - libmysqlclient.so.16 problem
dlong500
Solution to run
ldconfig
so that the system library linker took another look at the libraries it had, thus found the newly installed mysql lib.
I've added that command to the guide for clarification.
I have the same libmysqlclient.so.16 problem and the method listed in the help file is not working for me (i.e. nothing changes). I have Debian 6.0 x64 and do have the correct DA binaries/license. I've tried creating a soft link like the help page says and also tried a hard link with no difference. All file permissions are correct and the link is owned by mysql.
It appears that the ldconfig command is not recognizing the link as it does not show up in the cache (ldconfig -p). Any ideas?
remikk
Poland
Solution from http://help.directadmin.com/item.php?id=236 doesn't work for me.
I have Debian 6.0 64bit.
After I update mysql from custombuild I have:
/usr/local/directadmin/directadmin o
/usr/local/directadmin/directadmin: error while loading shared libraries: libmysqlclient.so.16: cannot open shared object file: No such file or directory
/usr/local/mysql/lib# ls -l libmysqlclient*
-rw-r--r-- 1 mysql mysql 14762606 05-11 20:10 libmysqlclient.a
lrwxrwxrwx 1 mysql mysql       16 06-17 10:05 libmysqlclient_r.a -> libmysqlclient.a
lrwxrwxrwx 1 mysql mysql       17 06-17 10:05 libmysqlclient_r.so -> libmysqlclient.so
lrwxrwxrwx 1 mysql mysql       17 06-17 10:05 libmysqlclient_r.so.18 -> libmysqlclient.so
lrwxrwxrwx 1 mysql mysql       17 06-17 10:05 libmysqlclient_r.so.18.0.0 -> libmysqlclient.so
lrwxrwxrwx 1 mysql mysql       20 06-17 10:05 libmysqlclient.so -> libmysqlclient.so.18
lrwxrwxrwx 1 root  mysql       20 06-17 10:28 libmysqlclient.so.16 -> libmysqlclient.so.18
lrwxrwxrwx 1 mysql mysql       24 06-17 10:05 libmysqlclient.so.18 -> libmysqlclient.so.18.0.0
-rwxr-xr-x 1 mysql mysql  6842027 05-11 20:10 libmysqlclient.so.18.0.0
[code]
Could you help me?
ldjnetworks
I ran into the same issues. I'm not running 64 bit but this solved it for me on Debian 6, 32-bit.
cd /usr/local/mysql/lib
rm -f libmysqlclient.so.16
apt-get update
apt-get install libmysqlclient16
nango
I update DA from 3.8 to last after some minutes DA login page was not available and I tried to restart DA service with no result.
I have CentOS X86_64. Ther error is:
/usr/local/directadmin/directadmin: error while loading shared libraries: /usr/lib64/libmysqlclient.so.16: file too short
ldconfig: File /usr/lib64/libmysqlclient.so.16 is empty, not checked.
The help was not useful for me.
Xtracy
I've updated DirectAdmin from 1.38.4 to 1.39 (through the control panel) and now DA won't start.
When I try to start it from the shell I get:
service directadmin start
Starting DirectAdmin: /usr/local/directadmin/directadmin:
cannot open shared object file: No such file or directory [FAILED]
I've checked (and tried) the help but without resolve.
I also tried linking so.15 to so.16 but then get the following error:
 /usr/lib64/libmysqlclient.so.16: version `libmysqlclient_16'
not found (required by /usr/local/directadmin/directadmin) [FAILED]
(using CentOS 5.5, 64bit)
nango
My Problem Solver by:
Update Mysql from 5.0 to 5.1 with custom build. then rebuild php. update DA manual.
nango
Hi Xtracy
I had this problem today exactly. heck my above solution.
klaasvaak
same problem here
centos 64 bit -> updates directadmin to 1.39 and directadmin wont start anymore.
from command line i saw
Starting DirectAdmin: /usr/local/directadmin/directadmin: error while loading sh
le or directory
here what i did
1. updates my sql to mysql=5.1 with the custombuild
2. then i rebuild php
3. then cd /usr/local/directadmin
./directadmin p
cd scripts
./update.sh
/etc/init.d/directadmin restart
and then from
:2222/CMD_SHOW_SERVICES full reboot
and directadmin 1.39 is running again.
Xtracy
Thank you for your replies, unfortunatly I can't upgrade to mySQL 5.1 at the moment.
simmer
Got the same problem, fixes don't work for me on Centos 5.5 x64
wget -O /usr/lib64/libmysqlclient.so.15 [url]http://files.directadmin.com/services/es_5.0_64/libmysqlclient.so.15[/url]
chmod 755 /usr/lib64/libmysqlclient.so.15
ldconfig
binarygrind
same problem here
le or directory
here what i did
./directadmin p
cd scripts
./update.sh
and then from
Woot! Thanks, now DA is backup and running.
yonatanp
Israel
ldconfig
same issue here
 directadmin]# ./directadmin o
./directadmin: error while loading shared libraries: libmysqlclient.so.16: cannot open shared object file: No such file or directory
# service directadmin start
Starting DirectAdmin: /usr/local/directadmin/directadmin: error while loading shared libraries: libmysqlclient.so.16: cannot open shared object file: No such file or directory
                                                           [FAILED]
 uname -i
x86_64
centos 5.6
mysql 5.0
php-cgi 5.2-latest
can't update to 5.1 due to compatibility issues.
DirectAdmin Support
Administrator
Staff member
I found that the CentOS 5 64-bit binaries were linked to libmysqlclient.so.16 when they might have not been before. I'm going to rebuild them and force them not to link to it (they'll have internal mysql code instead).
Once I release 1.39.1, use this guide to grab the new version.
yonatanp
Israel
Hi john,
thank you for the prompt replay,
i have rolled back the binary on the server for now to 1.38.4
looking forward for updates.
Have a good day/night :)
DirectAdmin Support
Administrator
Staff member
The CentOS 5 64-bit binary package is now in the system. You can use the mentioned guide to get these new binaries (1.39.1).
nobaloney
California
John,
Hopefully you'll announce when the new binaries are ready for install from the control panel; I (and I'd presume others) will wait until all is sorted out.
Thanks.
jw00dy
Utah, USA
Thank you for this fix. I have upgraded to 1.39.1 and it's working as it should now. DA is running now and I don't have any errors.
chenpang
hi!
on my debian(32 bits) system,the error is :
error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory
i type the command and it work pertect!
# ln -s /usr/local/mysql/lib/libmysqlclient.so.18 /usr/lib/libmysqlclient.so.18
(suppose your MYSQL is installed in /usr/local)
chenpang
nealdxmhost
Los Angeles CA
I am in the middle of setting up a server with Ubuntu 10.04 64 bit and I too am having this problem as well during the install. During the first run and when it spit out the error message it told me that I needed to do the following;
 apt-get install libdb4.8-dev libperl-dev libsasl2-dev
So I did that and ran setup again and then it did this;
So then I followed the suggestion posted here http://help.directadmin.com/item.php?id=236 and did this;
wget -O /usr/local/mysql/lib/libmysqlclient.so.16 http://files.directadmin.com/services/debian_5.0_64/libmysqlclient.so.16
chmod 755 /usr/local/mysql/lib/libmysqlclient.so.16
ldconfig
Now I am running setup again and I will keep you posted.
