Having errors after installing the plugin.
at first view , the plugins seems very nice , but after installing it , and choosing awstats as default , and use static page view.
i get the following error after trying to view the stats
http://www.janvandel.be/stats/
			Error: Couldn't open server log file "/var/log/httpd/domains//janvandel.be.log" : Permission denied
Setup ('/etc/awstats/awstats.janvandel.be.conf' file, web server or permissions) may be wrong.
Check config file, permissions and AWStats documentation (in 'docs' directory).
This error is for al the domains i choosed awstats...
When setting the plugin back to webalyzer , how do i make that the stat is generated imediatly ? if i dont want to wate fot the auto update ?
I tried to set the permissions of all config files to 644 or even to 777 and also the log files...
But that diddend resolve the problem...
Plz help...
- update -
- Seems to after updating most of the permissions , i got the awstats on that site running , but on other domeins not ( even on same server )
- the sites with awstats , some work , other not , the sites with webalizer wont work...
In the webalizer config window i also get the following error
Warning: Variable passed to each() is not an array or object in /usr/local/directadmin/plugins/Stats_Control/user/common.php on line 63
