Is that DA 1.45.4, latest version of the plugin and the CustomBuild script?
AndyII, was that a question for me?Do you consider this loading time slow?
Please let me know the output of:
Code:cd /usr/local/directadmin/custombuild time ./build settings_json > /dev/null time ./build version > /dev/null
Thank you.
It takes more than 2 seconds to execute the script, but it would be hard to say where are the other 3 seconds... What about the other tabs, do they work faster? May you list loading times of them? Also, I'm not yet sure about the default tab, "Edit options" might not be the most often used tab, so don't hesitate to post your suggestions about that too![]()
Would there be more users that think that "Update software" should be the index page (main tab)?I like the idea.
