turnersloane
- Sep 27, 2006
ClamAV fails to start after update to v0.97.3. After the update/compile, I receive these error messages:
Restarting freshclam.
Shutting down freshclam: [FAILED]
Starting freshclam: ERROR: This tool requires libclamav with functionality level 63 or higher (current f-level: 62)
[FAILED]
Restarting clamd.
cat: /var/run/clamd.pid: No such file or directory
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
Starting clamd daemon: /usr/local/sbin/clamd
Bytecode: Security mode set to "TrustSigned".
LibClamAV Error: cl_load(): Can't get status of /var/lib/clamav
ERROR: Can't get file status
Starting freshclam daemon: /usr/local/bin/freshclam -d -c 6
Running ./build versions still shows that an ClamAV can be updated to to v0.97.3. It's as if the update didn't take?
Google search for "This tool requires libclamav with functionality level 63 or higher" didn't really reveal helpful information.
Any ideas?
Thanks,
Sloane
[FAILED]
Restarting clamd.
Any ideas?
Thanks,
Sloane
