JS errors :
d3pie error: no data supplied.
DevTools failed to parse SourceMap:
https://ns2.myhost.gr:2222/CMD_PLUGINS_ADMIN/rspamd/bootstrap.min.css.map.raw
js.raw?r=lib/d3pie.min.js:9 d3pie error: no data supplied.
initialCheck @ js.raw?r=lib/d3pie.min.js:9
c.recreate @ js.raw?r=lib/d3pie.min.js:9
c.updateProp @ js.raw?r=lib/d3pie.min.js:9
ui.drawPie @ js.raw?r=lib/../app/rspamd.js:376
getChart @ js.raw?r=lib/../app/stats.js:169
success @ js.raw?r=lib/../app/stats.js:220
complete @ js.raw?r=lib/../app/rspamd.js:243
u @ js.raw?r=lib/jquery-3.3.1.min.js:2
fireWith @ js.raw?r=lib/jquery-3.3.1.min.js:2
k @ js.raw?r=lib/jquery-3.3.1.min.js:2
(anonymous) @ js.raw?r=lib/jquery-3.3.1.min.js:2
load (async)
send @ js.raw?r=lib/jquery-3.3.1.min.js:2
ajax @ js.raw?r=lib/jquery-3.3.1.min.js:2
queryServer @ js.raw?r=lib/../app/rspamd.js:263
(anonymous) @ js.raw?r=lib/../app/rspamd.js:524
each @ js.raw?r=lib/jquery-3.3.1.min.js:2
success @ js.raw?r=lib/../app/rspamd.js:523
load (async)
ui.query @ js.raw?r=lib/../app/rspamd.js:502
statWidgets @ js.raw?r=lib/../app/stats.js:174
(anonymous) @ js.raw?r=lib/../app/rspamd.js:90
a @ js.raw?r=lib/visibility.min.js:5
setInterval (async)
t._run @ js.raw?r=lib/visibility.min.js:5
t.every @ js.raw?r=lib/visibility.min.js:5
tabClick @ js.raw?r=lib/../app/rspamd.js:89
(anonymous) @ js.raw?r=lib/../app/rspamd.js:289
dispatch @ js.raw?r=lib/jquery-3.3.1.min.js:2
y.handle @ js.raw?r=lib/jquery-3.3.1.min.js:2
trigger @ js.raw?r=lib/jquery-3.3.1.min.js:2
(anonymous) @ js.raw?r=lib/bootstrap.min.js:7
f @ js.raw?r=lib/bootstrap.min.js:7
c.activate @ js.raw?r=lib/bootstrap.min.js:7
c.show @ js.raw?r=lib/bootstrap.min.js:7
b @ js.raw?r=lib/bootstrap.min.js:7
t @ js.raw?r=lib/jquery.stickytabs.min.js:9
c.fn.stickyTabs @ js.raw?r=lib/jquery.stickytabs.min.js:9
displayUI @ js.raw?r=lib/../app/rspamd.js:172
success @ js.raw?r=lib/../app/rspamd.js:323
ui.connect @ js.raw?r=lib/../app/rspamd.js:318
(anonymous) @ js.raw?r=main.js:57
execCb @ js.raw?r=lib/require.min.js:5
check @ js.raw?r=lib/require.min.js:5
(anonymous) @ js.raw?r=lib/require.min.js:5
each @ js.raw?r=lib/require.min.js:5
emit @ js.raw?r=lib/require.min.js:5
enable @ js.raw?r=lib/require.min.js:5
init @ js.raw?r=lib/require.min.js:5
completeLoad @ js.raw?r=lib/require.min.js:5
onScriptLoad @ js.raw?r=lib/require.min.js:5
load (async)
Show 55 more frames
