Could we migrate Roundcube address data from cpanel with cpanel_to_da automatically? Is it possible?
Thanks,
Melih
We migrated 8 cpanel servers and no roundcube address records migrated.
Thanks,
Melih
Hello
i have this error when try to restore
PHP Parse error: syntax error, unexpected '[' in /usr/local/directadmin/scripts/cpanel_to_da/cpanel_sqlite_da_roundcube.php on line 24
i'm using the latest version 0.023
php /usr/local/directadmin/scripts/cpanel_to_da/cpanel_sqlite_da_roundcube.php
./build cpanel_to_da
wget -O /usr/local/directadmin/scripts/cpanel_to_da/cpanel_to_da.sh https://custombuild.eu/cpanel/cpanel_to_da.sh.0.0.24
* Fixed email and domains limits
* "Account creation time" gets transferred
* Email quota limit gets transferred
* SSH/CGI bin are turned off by default if not found enabled in user config
* If Let's Encrypt cert is older than 90 days - do not setup auto-renewal for it
New version 0.0.24 is available for testing:
Code:wget -O /usr/local/directadmin/scripts/cpanel_to_da/cpanel_to_da.sh https://custombuild.eu/cpanel/cpanel_to_da.sh.0.0.24
Changelog:
Code:* Fixed email and domains limits * "Account creation time" gets transferred * Email quota limit gets transferred * SSH/CGI bin are turned off by default if not found enabled in user config
Thanks for update. Is there an issue with add-on domains? I have many clients with add-on domains inside their accounts. @kebirhost says that there is an issue with that. We are about to move our cPanel servers to DirectAdmin soon. Should I be worried? Or should I wait for a fix?![]()
i have try to migrate a server and in all domains i have the following error:
Error writing db file for xxxxx.com : Unable to save dns zone: named-checkzone returned:
loading "xxxxx.com" from "/var/named/xxxxx.com.db.temp.18897" class "IN"
dns_rdata_fromtext: /var/named/xxxxx.com.db.temp.18897:48: unbalanced quotes
zonexxxxx.com/IN: loading from master file /var/named/xxxxx.com.db.temp.18897 failed: unbalanced quotes
zone xxxxx.com/IN: not loaded due to errors.
However the cpanel bind work fine with the same config with unbalanced quotes.
default._domainkey 14400 IN TXT "v=DKIM1; k=rsa; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEA8bAxlCV/fC2MA3+y0rJyS0CtuTUJVOxasmaAMS2cSiPm1hASBl20JSUKE0V87reSlw+oUG7vGH7kKny9UhgudHfYbgxM+mto1DK96d21wlDNUpxz5Eir1DrcW+v8JT09ltQhNuYFr8k4oZppteFutrnJhXyQ28SuvdzI/9PdJJiYCmUrTPmHnI+hHwS2NHAXb" vHFFDRPqVLKFRiMlOLY66BmkzpwheUMQgr1r1HTbgRO1AIY9Zqt8zOybtK3ygk4wSKqoKw22ZEmzdNlrfMjijKClbtAz0p+EhZu9B6Fxw+iWaX6aNIUQWT0AZXhepyQGoiGT7tj/8EbqJlwH7a7OwIDAQAB\;
