ShobhaPatwal
- Nov 19, 2019
How to make changes in evolution skin adding custom html tags which will see only to users , not to admin & reseller?
I want to add banner on top and in sidebar a div made through html code.
Is it possible?
How to do through cssTo customize widget, you may replace it with https://forum.directadmin.com/showthread.php?t=57994, and add/change any code needed. Regarding top-left place - it's not customizable at the moment (unless you do CSS changes, using external CSS included in Customize Evolution Skin).
This oneWhere I can found the html code to edit the code of theme
I have found out how to get the Icons working. on the DirectAdmin demo site demo.directadmin.com it has a drop down called Default Icon Pack how do I get this as i want to change my icons to the Modern Icons.
Matthew
You can upload your icon and change icon for each menu in "customize evolution skin"I have found out how to get the Icons working. on the DirectAdmin demo site demo.directadmin.com it has a drop down called Default Icon Pack how do I get this as i want to change my icons to the Modern Icons.
Matthew
