Migdiradmin
 - Jan 5, 2020
Its my first instalation with Directadmin , after i configure this without problems.
VPS 3GB ram
php 7.4
mariadb10.4
nginx_apache (mod_ruid2 disabled)
I tried to install waf comodo & Modsecurity to protect the host.
./build set modsecurity yes
./build set modsecurity_ruleset comodo
./build modsecurity (I stoped here, because give-me an error)
./build modsecurity_rules
./build rewrite_confs
./build modsecurity
			VPS 3GB ram
php 7.4
mariadb10.4
./build modsecurity
	 Found DirectAdmin version v.1.59.5
which: no sudo in (/bin:/usr/bin:/usr/local/bin:/usr/sbin:/usr/local/sbin:/usr/local/apache/bin:/usr/local/apache/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin)
ERROR: Not found SUDO utility.\nSUDO required for plugin.\nPlease setup it manually, then rerun this installation.
Can't open /etc/cwaf/main.conf: No such file or directory.
./build: line 19630: /usr/local/cwaf/scripts/updater.pl: No such file or directory
Defaulting to Comodo WAF SecDefaultAction...
Installation of ModSecurity Rule Set has been finished.
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
