First installation modsecurity error!
Migdiradmin
Its my first instalation with Directadmin , after i configure this without problems.
VPS 3GB ram
php 7.4
mariadb10.4
nginx_apache (mod_ruid2 disabled)
I tried to install waf comodo & Modsecurity to protect the host.
./build set modsecurity yes
./build set modsecurity_ruleset comodo
./build modsecurity (I stoped here, because give-me an error)
./build modsecurity_rules
./build rewrite_confs
./build modsecurity
 Found DirectAdmin version v.1.59.5
which: no sudo in (/bin:/usr/bin:/usr/local/bin:/usr/sbin:/usr/local/sbin:/usr/local/apache/bin:/usr/local/apache/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin)
ERROR: Not found SUDO utility.\nSUDO required for plugin.\nPlease setup it manually, then rerun this installation.
Can't open /etc/cwaf/main.conf: No such file or directory.
./build: line 19630: /usr/local/cwaf/scripts/updater.pl: No such file or directory
Defaulting to Comodo WAF SecDefaultAction...
Installation of ModSecurity Rule Set has been finished.
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
I have some questions about this comands.
./build modsecurity
wen i use this comands i have only comodo rules right?
What is the modecurity_rules?
What is the best Comodo rules or owasp for nginx_apache ?
./build modsecurity
This forum(community) have low activity.
After searching and testing i have some answers.
Yes
??? I think is the modsecurity rules i have chosen (owasp or comodo)
After some tests i think owasp is more safety and fast, but more false positives out of the box.
CSF doesnt ban the ip and i use lf_modsec to ban but nothing.
The modsecurity is working ok.
Wen i test
https://www.domain.com/?q="><script>alert(1)</script>
406 - error
Not Acceptable
An appropriate representation of the requested resource could not be found on this server.
Now CSF its working with owasp, maybe some update from CSF or owasp.
IP: xxxxxx
Failures: 5 (mod_security)
Interval: 3600 seconds
Blocked: Permanent Block [LF_MODSEC]
Log entries:
[Wed Jan 06 15:00:35.889112 2021] [:error] [pid 2147:tid 139674525648640] [client xxxxxxxx] [client xxxxxxx] ModSecurity: Access denied with code 406 (phase 2). Pattern match "^[\\\\d.:]+$" at REQUEST_HEADERS:Host. [file "/etc/modsecurity.d/REQUEST-920-PROTOCOL-ENFORCEMENT.conf"] [line "735"] [id "920350"] [msg "Host header is a numeric IP address"] [data "xxxxxxx"] [severity "WARNING"] [ver "OWASP_CRS/3.3.0"] [tag "application-multi"] [tag "language-multi"] [tag "platform-multi"] [tag "attack-protocol"] [tag "paranoia-level/1"] [tag "OWASP_CRS"] [tag "capec/1000/210/272"] [tag "PCI/6.5.10"] [hostname "xxxxxx"] [uri "/"] [unique_id "X-XQk1VwIpFeV0RSZ@0qPwAAAX0"]
Your DA version is really old. You might upgrade.
It is just community forum. You only have 96 post yourself...
Yes
You have the ones you chose in the ./build set modsecurity_ruleset comodo command
What is the best
What works to day might not work tomorrow.
MODSEC_LOG =
Is this set correctly in csf
You might look in
cat /var/log/httpd/error_log
or it might be here
you might work through all of this
  1. Enable mod_security. See the CustomBuild Faq for available rulesets and options.
I see in a double post you say its working.. Glad you got it going. Please try not to double post.
