Is this a bug? > no ioncube is not a valid option
shanky
Setting up a new server it get this error:
Please select if you would like to use ionCube (yes/no):no
ioncube is not a valid option.
Two arguments must be given for the function
Please select if you would like to use ionCube (yes/no):yes
Please advice.
Please advice.
It was fixed in CB 2.0 rev. 2425, introduced with the support of php_extensions.conf. Installation with default settings would finish (you could change the setting later) - else just update CustomBuild. Sorry for this :)
Oh good!!!
1688542101790-png.6985
Hi smtalk.
I have the same problem and do not know how to resolve it. How should I fix it?
I really appreciate your help.
Hi. Sorry, I don't understand what I should do to resolve the above-mentioned problem.
Would you please help me?
