if it’s not a secret reference how to add do not tellHello,
Whenever you need to restart PHP-FPM and/or web-server it can be done in DirectAdmin at admin level, and as root in a shell console. If you are a regular user of a shared hosting company you will need to contact your hosting company for this.
you will not prompt how to change max_input_vars value memory_limit like you can change the value inside directadmin then these attempts to update the system are already enraging. can not alreadySearch in internet on how to restart services in a Linux console as root. It's a common process for all Linux-based servers.
In directadmin navigate to 'Service Monitor' as admin and restart what you need.
The php.ini file was changeable. How can I apply it?
Well.... to make php changes effective, restart the webserver service.The php.ini file was changeable. How can I apply it?
could you write in which categoryWell.... to make php changes effective, restart the webserver service.
I found only the update that killed my billing. I have no idea how to update for php.ini system. over this topic for weeks to interpret 100 answers and normal is not visible. there is no php.ini from the panel as in ispmgr or cpanel. it’s not clear I’ve been hanging around for a day looking for commands to reboot.Excuse me? What do you mean which category? Are you a server admin or not?
It's the same as restarting php-fpm, Zeiter answered that already for you.
Isn't there? Then you haven't looked at the correct place. I use the enhanced skin because that's a lot easier but look at your admin panel.there is no php.ini from the panel as in ispmgr or cpanel.
Value of max_input_vars 1000 1000 in file 5000 But the memory_limit 2048M has changed. I'm lost. |
Do I need to change the value of max_input_vars to 5000, do I just start searching for php.ini files?I don't quite understand. The memory_limit is a seperate setting in php.ini file.
If you have different values in a phpinfo.php file then in your php.ini file, you probably have multiple php.ini files and are using the wrong one at this time of have to adjust them all.
Now I'll see what is in phpinfo.phpI don't quite understand. The memory_limit is a seperate setting in php.ini file.
I don't know. If you want to change things in php.ini is up to you. If you need it, I would search for php.ini files and change them all.Do I need to change the value of max_input_vars to 5000, do I just start searching for php.ini files?
only 73 php my https://www.my.salyname.com/phpinfo.php/I don't know. If you want to change things in php.ini is up to you. If you need it, I would search for php.ini files and change them all.
They should be in directory's like:
/usr/local/php71/lib/php.ini
/usr/local/php72/lib/php.ini
/usr/local/php73/lib/php.ini
depending on which are present and used.
I did it first. all the same you such garbage to me to contact support DirectAdmin perhaps will helpWell... it's in my answer, in that case:
/usr/local/php73/lib/php.ini and change it there and restart the webserver.
If it won't fix things, it might be better to send in a ticket.
