sending email fail
iPwsite
We are unable to send email via round cube.
"An error occurred.Close
SMTP Error (451): Failed to add recipient "[email protected]" (Temporary local problem - please try later)."
Please check the attached file.
Any advise please?
Login via SSH to your server.
cd to /var/log/exim
use either nano or vi (vim) to open mainlog and see if you can find references to this error.
If you're not an admin (so not a DA customer) you're at the wrong place, in that case you have to contact your host.
cd /var/log/exim
what's is the rest of the commands to grab the log details please
is this article helpful?
SMTP Error (451): Failed to add recipient "email" (Temporary local problem - please try later).​
Here is the steps to follow :-
1. run /scripts/mailperm --force after that run /scripts/updateuserdomains
2. also can run /scripts/forcelocaldomain domain.com (this will write the domain.com to /etc/localdomains file)
3. manually add the domain to /etc/localdomains file
NOTE : Please ensure the domain is in /etc/localdomains file.
I'm sorry. I like to be helpfull, but I'm not going to give a course in basic admin knowledge. I already mentioned to look with nano or VIM because for example with the Nano editor you can easily search for strings.
The article indeed might be helpful too.
