DirectAdmin 1.62.0 has been released
DirectAdmin Support
Administrator
Staff member
We're excited to announce the full release of DirectAdmin 1.62.0.
The full list of changes are listed here:
https://directadmin.com/versions.php?version=1.620000
Some of the new features:
  • HTTP/2 support on port 2222 via the new Go wrapper
  • Automatic SSL Certificate management
  • CGroup per-User resource limit enforcement (Pro Pack)
  • Nginx: User selectable templates (eg: WordPress, etc) (Pro Pack)
  • Nginx Unit for inter-process web redirection/processing (Pro Pack)
  • Command line CLI calls for API generation to embed into your requests
  • Global IP Selection
  • Tally runs in new dataskq process after restore, so success message returns much faster
  • New internal Nginx location template structure, for cleaner insertions of various /paths
  • Restore: Reseller override to specify who to restore under
  • User Backup: select which domains to backup
  • Skin/Evo Customization: favicon, symbol, symbol2 (more custom images)
  • Admin IP: Additional IP information direct from device
  • SPF: now includes server's default IPv6 by default for new zones
  • Option for per-domain Nginx-only (disable proxy) for webserver=nginx_apache
  • Hooks: special exit code 42 for included output, even with no error
  • Allow JSON input for all POST requests, instead of url-encoded data (BETA)
  • Load Average in System Information
  • Referrer check to store port UPDATE WILL LOG YOU OUT
  • systemd directadmin daemon will now run in "foreground" mode within systemd, instead of daemon mode.
  • Default cookie setting: SameSite: Lax
  • Each filesystem type is now auto-detected (ext4, xfs, etc)
  • Option to reduce the number of languages shown (da.conf: language_list)
  • Redis (Pro Pack)
Plus many bug fixes.
To update to 1.62.0, please login to your copy of DirectAdmin, and go to:
Admin Level » Licensing/Updates » Update DirectAdmin
Behavior Changes
json=yes calls to the user=fred GET version of these calls have output changes
  • CMD_API_SHOW_USER_DOMAINS
  • CMD_SHOW_USER
  • CMD_API_SHOW_USER_USAGE
  • CMD_API_SHOW_USER_CONFIG
Please test your API calls if you're using these, as the "quota" value was not in the correct format before. It's now an array.
There is a GET option which lets you revert to the old value, as a workaround (but please update your scripts to use the corrected array method)
As this is a massive new version, even though it's been in tested for quite a long time now, there may still be bugs.
If any are found, let us know and we'll get fixes out as soon as we can.
Thank you,
i am getting the following error, i have validated my license also all ok
This is an automated message notifying you that an error has occurred while trying to update the software.
The generated error message is as follows:
md5sum mismatch from header X-md5: 97999a688e6b34b91899bde5b1fb0f1e and /usr/local/directadmin/update.tar.gz=1eef1edef3ee1fef2f31a2335054cf68
The download of /usr/local/directadmin/update.tar.gz has failed the md5sum check. Please check the file and retry the update again. Not extracted.
For debugging purposes, this file came from: http:/x.x.x.x.74//stable_releases_X/packed_es80_64.tar.gz
Trying another random redirection URL from the same control server
For debugging purposes, this file came from: http://x.x.x.168//stable_releases_X/packed_es80_64.tar.gz
Unable to connect to any site for the update
There were md5 errors from all servers, above. Please send report to DirectAdmin Support.
Request: /cgi-bin/daupdate?lid=XXXXXX&uid=XXXXXX&redirect=ok&downloadserver=files%2Dca%2Edirectadmin%2Ecom
Please contact JBMC-Software, including the error message. Failure to do so could result in an inactive control panel.
97999a688e6b34b91899bde5b1fb0f1e is the old md5sum for the 1.61.5 es8 pack.
There would likely be a moment in time where the sync of packs to the mirrors won't match the md5 sent with the master header response.
I'm assuming this is the case here.
Please give it another go and let us know if the issue re-occurs.
In Licensing / Updates I see
Server Version 1.61.5
Current Available Version 1.6.2
It should be Current Available Version 1.62.0
same error.
yep, same here.
yep same here, I just noticed that!
DirectAdmin Values​
Compiled on CentOS 8.0 64-Bit
Compile Date Sep 26 2020, 18:16:41
Last Updated Tue Sep 29 19:37:57 2020
Last Restart Thu Jun 10 11:25:47 2021
Found our old update box was being queried, so I've synced that up, should be good now.
As for the "1.6.2" version, that looks like an Evo/GUI bug, I'll push a fix request to the devs.
The back-end would know of the correct version.
hi
directadmin new version v1.6.02 have bug not update see pic for error
*removed* (same error as above)
yep it works now. Is the new interface also available in the update?
This is an automated message notifying you that the DirectAdmin software has been successfully updated.
To view what has changed, please visit:
Hi Again,
Is is possible to use cgroup pro pack features, until the pro pack is available! ???
Latest version of DirectAdmin: 1.62.0
Installed version of DirectAdmin: 1.62.0
from ./build versions
