- Feb 27, 2003
We're excited to announce the full release of DirectAdmin 1.62.0.
The full list of changes are listed here:
https://directadmin.com/versions.php?version=1.620000
Some of the new features:
To update to 1.62.0, please login to your copy of DirectAdmin, and go to:
Behavior Changes
json=yes calls to the user=fred GET version of these calls have output changes
There is a GET option which lets you revert to the old value, as a workaround (but please update your scripts to use the corrected array method)
As this is a massive new version, even though it's been in tested for quite a long time now, there may still be bugs.
If any are found, let us know and we'll get fixes out as soon as we can.
Thank you,
- HTTP/2 support on port 2222 via the new Go wrapper
- Automatic SSL Certificate management
- CGroup per-User resource limit enforcement (Pro Pack)
- Nginx: User selectable templates (eg: WordPress, etc) (Pro Pack)
- Nginx Unit for inter-process web redirection/processing (Pro Pack)
- Command line CLI calls for API generation to embed into your requests
- Global IP Selection
- Tally runs in new dataskq process after restore, so success message returns much faster
- New internal Nginx location template structure, for cleaner insertions of various /paths
- Restore: Reseller override to specify who to restore under
- User Backup: select which domains to backup
- Skin/Evo Customization: favicon, symbol, symbol2 (more custom images)
- Admin IP: Additional IP information direct from device
- SPF: now includes server's default IPv6 by default for new zones
- Option for per-domain Nginx-only (disable proxy) for webserver=nginx_apache
- Hooks: special exit code 42 for included output, even with no error
- Allow JSON input for all POST requests, instead of url-encoded data (BETA)
- Load Average in System Information
- Referrer check to store port UPDATE WILL LOG YOU OUT
- systemd directadmin daemon will now run in "foreground" mode within systemd, instead of daemon mode.
- Default cookie setting: SameSite: Lax
- Each filesystem type is now auto-detected (ext4, xfs, etc)
- Option to reduce the number of languages shown (da.conf: language_list)
- Redis (Pro Pack)
Admin Level » Licensing/Updates » Update DirectAdmin
Behavior Changes
- CMD_API_SHOW_USER_DOMAINS
- CMD_SHOW_USER
- CMD_API_SHOW_USER_USAGE
- CMD_API_SHOW_USER_CONFIG
Thank you,
