DirectAdmin 1.62.5 has been released
DirectAdmin Support
Administrator
Staff member
We're pleased to announce the release of DirectAdmin 1.62.5.
This is a minor release with some handy new features and a few bug-fixes.
All changes listed here:
Noteworthy New Features
Noteworthy Bug-Fixes
The update channels (accessible through your Admin Level » Licenses/Updates) will allow you to delay the shown "Latest Version" seen by DA, in case you want to wait for things to have more testing in the wild before updating. We'll change this delayed "stable" version after an amount of time we feel is sufficient to be sure there are no major issues in the release. (Eg: ballpark, 2 weeks, at our discretion).
To update, go to your Admin Level » Licenses/Updates » Update DirectAdmin
Will this work along custombuild update script as well? I believe customscript will update DA if configured to auto update web apps.
Yes, the build script does DA update requests through the task.queue, which is called by the dataskq. As long as it's done through the DA binaries, it will respect the channels.
  • Like
Reactions: jca
@DirectAdmin Support
EDIT: Why is it not more possible to create reseller users with a subdomain ( as real domain itself) wen this main not sub domain is in use by another user/ reseller?
EDIT: IT is possible , but if protected settings for creating sub domain other user then no, then THIS BUG is there see below.
DA 1.62.5 evo latest custombuild user reserleler tried to create under SERVER ADMIN!
It was before possible if you create now a user with then error, but user and all created but not in DA GUI and ...
Example:
Server FQDN hostname: vps.domain.com
A reseller with that domain.com
Then other resellers with the "dummy" vps-1.domain.com , vps-02.domain.com was working now only error and still this BUG:
The only change with this update is the error is not saying the domain is in use by other but error without..
2021:08:12-21:22:12: getHomeDir: username is empty!:
2021:08:12-21:22:12: IP:writeBaseApache: user does not exist and wont be added to the ./data/admin/ips/2a01:....:0:0:0:100:0:0:1 file
2021:08:12-21:22:12: IP:writeBaseApache: user does not exist and wont be added to the ./data/admin/ips/2a01:....:0:0:0:100:0:0:50 file
2021:08:12-21:22:12: IP:writeBaseApache: user does not exist and wont be added to the ./data/admin/ips/2a01:....:0:0:0:100 file
2021:08:12-21:22:13: getHomeDir: username is empty!:
2021:08:12-21:22:13: IP:writeBaseApache: user does not exist and wont be added to the ./data/admin/ips/2a01:....:0:0:0:100:0:0:200 file
2021:08:12-21:22:13: IP:writeBaseApache: user does not exist and wont be added to the ./data/admin/ips/2a01:....:0:0:0:1000:0:300 file
2021:08:12-21:26:38: [ info] licence: refreshed
Edit:
Then after this in error log to:
2021:08:12-23:25:57: [error] proxy request error error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/ajax_count.raw?rand=0.27205000300472415
2021:08:12-23:25:59: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2021:08:12-23:26:57: is not a number. From '' > '0'
2021:08:12-23:39:40: [error] proxy request error error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/ajax_count.raw?rand=0.3194993887511819
2021:08:12-23:39:40: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2021:08:12-23:41:12: [error] http2: received GOAWAY [FrameHeader GOAWAY len=20], starting graceful shutdown source=stdlog
2021:08:12-23:41:15: [error] proxy request error error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/ajax_count.raw?rand=0.993152704174056
And after those ofcourse problems with those not users HMMM task queu log:
021:08:11-04:58:01: access is not a valid username because it matches the directadmin.conf option secure_access_group
2021:08:11-09:05:02: Unable to read user.conf for lie: Unable to open ./data/users/lie/user.conf for reading.<br>
No such file or directory<br>
2021:08:11-09:05:02: Unable to read user.conf for llie: Unable to open ./data/users/llie/user.conf for reading.<br>
2021:08:11-09:05:02: Error getting user 'admin' domain config file for domain (null)
2021:08:11-09:27:07: access is not a valid username because it matches the directadmin.conf option secure_access_group
SO BUG while should not be doing anything.
https://www.directadmin.com/features.php?id=925 , when this is set to prevent, so yes domain creations tries to prevent but lot of things created and then after errors with those.
We need a solution to have such faulty things deleted in GUI, and a CLI Script please https://forum.directadmin.com/threads/how-do-delete-a-user-from-command-line.61824/#post-334360
After updating to v1.62.5, I got this error while trying to access the DirectAdmin 2222
License IP mismatch​
Current Server Time: Fri, 13 Aug 2021 08:54:21 UTC
I tried manually re-download the license but no luck.
Any help would be much appreciated.
Thank you!
Regards,
Harry
(EVO this DA version Centos8) BUG IPV6 Asinged to user under reseller before a restore.
After restore no assigned ipv6 vissible under Modify that User also not possible to free that one
Nothing is possible with that ipv6 anymore it seems, not in evo not in enhanced, you can see it in admin ip management (pic2) only , but not in reseller ip (pic1) management and at user also nothing from that ipv6.
The with :300 is working under same reseller other useraccount the with : 200 gone after restore that user from other da server. ( restore in evo under users restore) ( but can't do anything with that ip, is not vissible in user or reseller only under admin overview you can see it is still asigned)
2a01:..........200 could not be removed, you must free it first.
2a01:.......200 is not set to 'free' or is still assigned to a reseller
Thank you!
Regards,
Harry
Try:
service startips start
service directadmin restart
I cannot update to latest version because md5 checksum fails
md5sum mismatch from header X-md5: 7d49505a075c28c50cbc9902ef609f9d and /usr/local/directadmin/update.tar.gz=3ccb1e7f2926774d148e62ea765d4ac5<br>
The download of /usr/local/directadmin/update.tar.gz has failed the md5sum check. Please check the file and retry the update again. Not extracted.<br>
For debugging purposes, this file came from: http://69.162.69.58//updates/current_releases_0834573945/packed_es80_64.tar.gz<br>
Trying another random redirection URL from the same control server<br>
Unable to connect to 216.144.255.179<br>
Unable to connect to secure socket: Some I/O error occurred. The OpenSSL error queue may contain more information on the error. If the error queue is empty (i.e. ERR_get_error() returns 0), ret can be used to find out more about the error: If ret == 0, an EOF was observed that violates the protocol. If ret == -1, the underlying BIO reported an I/O error (for socket I/O on Unix systems, consult errno for details).<br>
For debugging purposes, this file came from: http://104.128.54.74//updates/current_releases_0834573945/packed_es80_64.tar.gz<br>
For debugging purposes, this file came from: http://185.42.221.168//updates/current_releases_0834573945/packed_es80_64.tar.gz<br>
Trying next control server...<br>
md5sum mismatch from header X-md5: 7d49505a075c28c50cbc9902ef609f9d and /usr/local/directadmin/update.tar.gz=1c39cdfc519d5ee0b19e13954b8ad997<br>
For debugging purposes, this file came from: https://forum.directadmin.com//cgi-....0+64&downloadserver=files-de.directadmin.com<br>
Unable to connect to any site for the update<br>
There were md5 errors from all servers, above. Please send report to DirectAdmin Support.<br>
Request: /cgi-bin/daupdate?lid=148466&uid=50984&redirect=ok&os=ES+8.0+64&downloadserver=files%2Dde%2Edirectadmin%2Ecom<br>
What can I do?
Thanks in advance
YES PROBLEMS ALSO wen filemanager ( larger directory archive..) a error , and cant login again.
EDIT: THIS IS NO GOOD nothing possible anymore if try to admin login othere browser this comes see pic, if in same browser
OOPS!
Privileges needed to load the skin have not been granted for this account or unexpected issue has happened. Please contact your administrator.
beFor latest update 1.62.4 now 1.62.5 not this problem
See now after longer time wait in admin evo it all was da errro log:
2021:08:16-15:01:31: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2021:08:16-15:01:31: Error while sending file. Sent 8
2021:08:16-15:05:25: Socket write error: Unknown error: Connection reset by peer
2021:08:16-15:05:25: Error while sending file. Sent 50
2021:08:16-15:05:52: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2021:08:16-15:05:52: Error while sending file. Sent 54
Load Average​
1 minute0.44
5 minutes0.21
15 minutes0.12
Could this be same cause ?
SSL timeout issues after update, i can confirm that this is happening at our side too.
I hope they fix this issue as soon as possible...
UH more people having problems testing ssl-tools.net that was not before strange BLOCKING only 1 test is working now then no find / connection possible anymore.
This in LOG with the only one green emailtest :
2021-08-16 15:32:21 TLS error on connection from (ssl-tools.net) [2a00:c380:c0de:0:5054:ff:fe7e:d742] (SSL_accept): error:00000000:lib(0):func(0):reason(0)
2021-08-16 15:32:27 TLS error on connection from ssl-tools.net [185.55.116.145] (SSL_accept): error:00000000:lib(0):func(0):reason(0)
Richard has the same.
Topic: https://forum.directadmin.com/threa...k-please-check-your-internet-connection.64333
The same issue happens here since the last update (1.62.5). When trying to refresh the page a few times, the following error is displayed:
We run the command:
and access to the panel returns normally. After, everything stops working again.
I did a test with the DirectAdmin demo, and it's the same error (https://demo.directadmin.com:2222 - Login: admin_demo).
It appears to be a bug that needs to be fixed urgently.
Thank you!
Regards,
Harry
We have this problem on each server after every OS-restart (also since version 1.62.5)
Yes, I am also getting "Secure Connection Failed" errors since the update to 1.62.5. It doesn't happen every single request, but makes the panel basically unusable. Sometimes the panel loads but immediately throws "Unable to reach network. Please check your internet connection." errors, probably because of the same problem with a javascript request, or assets on the page fail to load.
We too are having exactly the same "secure connection failed" SSL issues with DA and "Socket write" errors in the DA error logs. DA is unusable so we have rolled back to a previous version until this is fixed (hopefully soon!).
BUMP THIS found no docs how to solve?
Also why is that group not editable in the DA GUI as ADMIN?
The BUG is wen a User exist with a asigned IPv6 after restore other DA server not having that same IPv6 this happens, with the Ipv4 no problems also other ip. ( older DA server years ago.. didn't have that secure acces group that way )
2021:08:17-00:10:01: IP 2a01:........:0:200 has a status of 'owned', but there are 0 Users currently using it
2021:08:17-06:51:01: access is not a valid username because it matches the directadmin.conf option secure_access_group
same problem here...
Same problem here aswell!
We tried the following
- downloading new license file
- restarting DA and rebooting the server
We also tried these commands that smtalk suggested.
Anyone else with a fix? Or suggestions to try?
For @DirectAdmin Support sofar i can see that problem with tls .....and co at our BOX was day's after the update 1.62.4 to 1.62.5 seen , but the same day that Letsencrypt did renew for HOSTNAME automaticly.
Maybe again a connection here with the Letsencrypt updates en DA LE script?
Centos 8 alma
