I am sure they will support it eventually it is Linux...I think they should also support Rocky Linux,
Maybe to avoid questions and confustions, it might be good to add it to the supported systems like change:We definitely have nothing against Rocky Linux.
| AlmaLinux / RHEL / CentOS to
VzLinux is already on a different line, like Cloudlinux is on a seperate line too, so those lines can't get too long imho.I agree.. list could get out of hand though.
RHEL and derived*
create a new lineFor Ubuntu just select the "Linux 64-bit static" OS in client portal
and for xxxx you can fill in Linux 64-bit static or Centos 8 whatever is needed. I think we use Centos 8 now for Alma.* Derived are Alma-, Rocky- and Oracle Linux. Just select the "xxxxxxxx" OS in the client portal
?And loose the FreeBSD support row.
I knew you would like that...You will be assimilated
www.bullfrag.com
Propably so long as Cloudlinux exists, and is not bought by the same company who bought cPanel and WHMCS .. hopefully ...So, if I go with AlmaLinux then how long until I have to re-provision a new server and move everything over again?
It's mentioned in the announcement thread here. If I remember correctly extra work and way too little customers using it to keep it supported.I can't remember why,
yeah, the same person who founded CentOS and and sold it.Alma is backed by a commercial company and I can see some advantages of that. But we see what happened to CentOS when it got bought by a commercial company. However it did last 7 more years. I am liking Rocky Linux because its founded by the person who founded CentOS originally. And I like the way the organization is set up. It just gives me a little more confidence. I could certainly be wrong.
Doesn't really matter, you can always switch to AlmaLinux from Rocky - seamlessly.Maybe Rocky will be sold in the future like its sister.
Let's hope so.Doesn't really matter, you can always switch to AlmaLinux from Rocky - seamlessly.
